Old 03-20-2009, 03:57 PM   #1
FusilliJerry82
FusilliJerry82 is on a distinguished road
Default 1999 SC1 General Auto Trans Problems
So almost a year ago, a friend of mine was in need of a car and his father had a 1999 (I think; its def the same gen) thats been sitting in his driveway since 2002/2003 (he beats the S**T out of his cars) that he said my friend could have if he fixed it.
So one day soon after that, I go over there and look at it and check the fluids and the transmission fluid is empty. So we get some fluid, fill it up, I jump the car and after some coaxing, it starts. So I let it run a bit which it was doing fairly well for having sat for years and soon after, put it in drive to see what happened. It seemed to work normally until my friend yelled and told me that tranny fluid was pouring out from under the car, and it was a POUR.
By this time, its almost completely dark out, so I have no chance in finding the source of the leak. And then conflicting schedules stop any chance at trying to take a stab again until very recently, when I crawled under to see if I could find any obvious leak, which of course I couldn't because it had more than a year to gush out.
My friend said recently that his dad brought it to a garage and said its not just the leak thats the problem but "the transmission has other problems" and the brakes need repair (which I can do myself I'm sure). Thing is, neither of them know anything about cars so I can't depend on them to relay any technical information, plus I very much doubt they even had the leak fixed, which is a shame because since I had it moving, even those few feet with fluid in it, I'm pretty sure I could get it into some drivable condition as long as the fluid didn't pull a Niagara Falls.
So is this a somewhat common occurrence on these models? I don't know the mileage but I'm sure its high and I know for a fact the tranny fluid was never changed besides leaking out at the end of its operations. Is there a common seal that might fail under extreme conditions?
Any information or stabs at a solution are welcome, thanks for your time.
FusilliJerry82 is offline   Reply With Quote
Old 03-20-2009, 04:06 PM   #2
tehSaturn
tehSaturn will become famous soon enough
2001 SW2
Default Re: 1999 SC1 General Auto Trans Problems
I bet the diff pin shot out of the tranny if its pouring out of it. But I'd wait till you get some more information from the other members here to make sure that's the case.
2001 SW2: 60k Miles @ 8/11
tehSaturn is offline   Reply With Quote
Old 03-20-2009, 04:39 PM   #3
FusilliJerry82
Now that you present that possibility, I looked it up elsewhere and all signs are pointing to it. I don't know how else that much fluid could spill out all over the ground that quickly without there being a fairly big hole in the trans case. If that's truly what it is, that's pretty much this cars death knell.
Old 03-20-2009, 05:13 PM   #4
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
You could pick up a junkyard trans for like a couple hundred and swap it out.
Unscrew the VSS (Vehicle Speed Sensor) from the trans and look in and you can see the diff pin.
On the car you have. See if the diff pin is gone haha. If it is, it ate the transmission for lunch!
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Fox Slaughter is offline   Reply With Quote
Old 03-20-2009, 05:20 PM   #5
tommyhawk13
tommyhawk13 is on a distinguished road
1995 SW2
Check the how to library forum for the richpin videos on how to inspect the dif pin. The vss sensor is easy to get to, and a simple adjustable wrench will do the trick.
tommyhawk13 is offline   Reply With Quote
Old 03-20-2009, 05:20 PM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
If fluid is coming out that fast, the diff pin is blown, absolutely no question about it. No reason not to fix it, or pass it on to someone like me who will buy it cheap, fix it and make a ton of money on it. I just picked up an '01 SW2 with a bad automatic for $350. Got a junkyard tranny for $75 and gave it to my sister to replace her SL2. Less than $500 into it replacing the tranny, buying the car, full tune up, ects, TAM, all new fluids, belt, etc. etc. Its an easy fix.
Certified Saturn Technician
Old 03-20-2009, 07:32 PM   #7
No great loss, in retrospect. Your friend's dad managed to experience, partly by his own (in)action, both the most common killers of our auto trannies: diff pin failure and fluid change neglect. The two are essentially unrelated, but a tranny that hasn't had its fluid maintenance (I'll bet a nickel the PO never read the owner's manual) was on borrowed time anyway; blowing the diff pin might have amounted to putting the tranny out of its misery.
Old 03-21-2009, 03:11 AM   #8
ahimsa1
ahimsa1 is on a distinguished road
1997 SW1
Quick question: In Richpin's diff pin inspection video, it looks like he's working on a manual transmission, and he starts out by draining some of the transmission fluid out. Is it necessary to drain fluid to do the inspection on an automatic transmission just like on the manual, and if so, how do you do that?
97 SW1 Auto 174k
ahimsa1 is offline   Reply With Quote
Old 03-22-2009, 11:50 AM   #9
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
As Squareback said, the diff pin is without a doubt blown. No need to even look at it, it needs a new transmission. You'll see it when you pull the trans out of the car...look very carefully for the 3" gaping hole behind the torque conerter.
1995sl1sohc is offline   Reply With Quote
1999 SC1 Electrical Problems mazurmj9 S-Series Tech 2 04-14-2008 09:53 AM
1999 Saturn SC1 Auto Tranny Leak...Please Help mtsumedi S-Series Tech 3 09-29-2007 12:37 PM
sc1 auto/trans issues sc1/omaha S-Series Tech 2 02-04-2007 03:27 PM
1999 SC1 Iginition Problems theterminator S-Series General 5 01-23-2006 08:13 AM
1999 SL-1 auto trans problems dgboult S-Series Tech 0 12-22-2005 12:38 AM
