Old 11-30-2021, 10:14 AM   #1
Chicopee L300
Chicopee L300 is on a distinguished road
Default Power steering components diagram
Trying to identify the hoses on the L300 power steering assembly, seems there are variations when I search for parts....going to replace the pump and want to replace all the hoses at the same time.
Any help appreciated.
Cheers !
Chicopee L300 is offline   Reply With Quote
Old 11-30-2021, 10:30 AM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
Default Re: Power steering components diagram
I looked on RockAuto and it does not look confusing. What year is your Saturn L300? If you have a 2004 you need to determine which engine you have other than that it is pretty straight forward.
2002 L200/5 Loaded, over 1/4 million miles!
Old 12-01-2021, 08:20 PM   #3
Chicopee L300
Thanks.......located one elsewhere.....trying to see if there is a power steering pressure switch in the system and where it is located....none shows up in power steering or senders/sensors....
Old 12-02-2021, 10:23 AM   #4
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
I dont believe there is a pressure switch in the P/S system
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 12-02-2021, 06:09 PM   #5
Chicopee L300
Thank You...I hope we are both right.....I had a stall issue after my p/s went out...some vehicles will react this way to loss of p/s pressure...figure my idle air control coughed...
Always something......lol...
Old 12-02-2021, 06:57 PM   #6
Are you troubleshooting an engine stalling problem or loss of power steering?
Old 12-03-2021, 02:10 PM   #7
Chicopee L300
It would be the later now....p/s failure happened before the stall....replacing hoses and pump...found a busted hose, car is old..not a surprise)...resulting failure might have caused pulley drag....either way codes came for stall as low rpm idle air, lean bank 1 and 2...starts and immediately stalls...sudden onset after p/s went out...btw squealing stopped after top off, and then failure after about 10 mins with bad hose leak...prob on pressure side...
Hoping after replacing p/s pump and hoses, things might be different before I approach the reason for sudden stalling
Old 12-03-2021, 03:00 PM   #8
Not an expert on power steering but there has never been a report within these forums of a power steering pump failure locking up to cause an engine stall. A general search of the internet may or may not reveal pwr steering failure contributing to engine problems.
A power steering hose leak is downstream relative to either the pressurized side feeding the steering rack or return hose. On the pressure side, leaking fluid would lower pressure as the pump continues to run until loss of fluid occurs. This would lower pump loads on the engine belt drive system. A return hose leak doesn't affect pump loads until loss of fluid occurs, again lowering pump loads on the engine. In practical terms, the pump (unless mechanically jammed from unforeseen reasons) losing oil simply lowers power demand from the engine.
Engine stalling, if directly related to the power steering pump, should be easily diagnosed by removing the drive belt and starting the engine for a brief run. The water pump won't run and a short engine run of less than a few minutes won't harm the engine. Manually rotating the pump by hand should result in some pressure against turning as the pump develops hydraulic pressure but shouldn't prevent turning.
You may have two separate problems - the hose damage and as yet undiagnosed problem of engine starting/stalling.
needed-wiring diagram-2006 steering wheel klwinter2 Vue General 1 10-15-2016 11:16 AM
2006 Ion - Dealer did power steering recall service ... still losing power steering! lbi2000 Ion General 2 08-11-2014 11:39 AM
Steering wheel diagram/exploded view? rayzur9 Vue Tech 3 04-08-2013 11:09 AM
Power steering pump leak at EVO - diagram needed gkainz S-Series Tech 1 08-22-2008 09:09 AM
Can't lube my steering components? MadAdam S-Series General 2 03-02-2005 04:58 PM
