Old 09-04-2017, 08:19 PM   #1
AprilSL1
AprilSL1 has a spectacular aura aboutAprilSL1 has a spectacular aura aboutAprilSL1 has a spectacular aura about
Roll Eyes 2000 Sl1 Hood Won't Release
Hello!
Ok, I went to open the hood, pulled the lever inside and the latch to the hood didn't release. The lever from the inside just smoothly lifted up.
Normally I feel a tug and the hood pops open.
How do I get the hood open to see what could be wrong? And is there any ideas of what is wrong? Parts I might need?
Thanks!
April
AprilSL1 is offline   Reply With Quote
Old 09-04-2017, 08:43 PM   #2
Default Re: 2000 Sl1 Hood Won't Release
Most likely the release cable broke. It's quite...uh..fun to open the hood now
One method: https://www.youtube.com/watch?v=KDPyIV9BwRU
Old 09-04-2017, 09:02 PM   #3
^^^That is probably the easiest way to do this job.
Old 09-05-2017, 03:48 PM   #4
AprilSL1
Ok, so I had a friend sit on the hood while I pulled the lever back. Then when they got off and lifted the hood it unlatched and I was able to open it.
Does that mean I need a new latch? and my cable is ok?
Old 09-05-2017, 04:51 PM   #5
toggenburg
toggenburg's Avatar
Sounds like it worked like it should, BUT, with the hood up, have someone pull up on the release lever, and someone else watch to see if the latch moves or not. No movement='s cable broken, or off one end or the other.
OR, you may need to lubricate the latch mechanism as it might be kinda gunked up and not releasing reliably.
Old 09-05-2017, 06:57 PM   #6
Flush it out with a spray cleaner that does not eat paint and use a dry lube on all pivot points. These bind up if ever oiled or greased. The actual contact point between the hood and latch needs a dry lube.
Old 09-05-2017, 07:55 PM   #7
AprilSL1
Ok great! Thank you, both for the advice
Would WD-40 be good enough to clean it up?
I'll get some dry lube also like you stated.
Hood release cable crimped, hood stuck in a released state Cards Ion Tech 3 01-06-2009 07:05 PM
Hood Release miadlor Vue General 3 03-24-2005 05:48 PM
Hood Release dnamit S-Series General 10 06-13-2004 08:04 PM
Hood release Esca Ion General 5 02-05-2004 11:55 AM
ION Hood Release saturncanuck Ion General 22 04-04-2003 03:02 AM
