Old 10-21-2010, 04:26 PM   #1
maddyh123
maddyh123 is on a distinguished road
Default passenger window glass
Hi
Ion3 2003 model
I have recently had a problem with passenger rear window glass. It not going up and down. Can anyone suggest what to do and what could be the problem. So that i can fix it myself.
Thanks
maddyh123 is offline   Reply With Quote
Old 10-21-2010, 06:00 PM   #2
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
Default Re: passenger window glass
Originally Posted by maddyh123 View Post
Hi
Ion3 2003 model
Thanks
I had a similar issue with my LR Window not rolling down and my driver's side power locks not working. (On different occasions)
As I recall I had a bad motor/relay(?) in the door which was replaced under warranty. For the Power Locks it was a bad wire(s) which I had a shop track down and patch (not in the door boot).
Have you tried both controls (driver and RR) to see if it gave different results? Have you tried both with Engine running and not? (I had better results with engine on) I also had results with repeat attempts pressing the button... I had a delayed response from the window, as if it was stuck or needed more power.
lgodave is offline   Reply With Quote
Old 10-25-2010, 12:32 PM   #3
maddyh123
I have tried both the ways with driver and RR and also when engine is on/off.
may be need to check with the motor/relay.
Thank you
Old 11-03-2010, 11:10 AM   #4
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Thank you
Did that check out?
chilipepper1327 is offline   Reply With Quote
will a 99sc passenger window (glass) fit a 97sc mad_nigerian S-Series Tech 2 04-10-2007 01:33 PM
WTB: 94 SL2 Upper Front Bumper Cover and Rear Passenger Door Glass chugg Classifieds 4 02-04-2006 06:53 PM
Girlfriend's stereo stolen, need to install passenger door glass dieseldog S-Series General 7 12-23-2005 08:33 PM
FS: passenger mirror GLASS bennett9000 Classifieds 0 02-20-2003 05:37 PM
How much to get window glass etched? sjt78 General Saturn Discussion 25 12-13-2002 10:12 PM
