Old 07-03-2021, 05:36 PM   #6841
bumpdraft
bumpdraft's Avatar
1998 SW2
Default Re: What did you do to your S-Series today...
Originally Posted by bumpdraft View Post
I took it on a 500 miles trip with a chainsaw in the trunk. On the way back, I noticed that straight-line highway tracking had degraded and there was a new, slight, straight-line vibration. My best guess is that the driver’s outer CV joint failed. It was stiff before I installed it last September and I suspect there was insufficient grease. Any acceleration-while-cornering produced more vibration than it had before this trip.
I ordered a Duralast Gold and a Dorman boot kit. I will look to see if this axle has enough grease, IF it is not too stiff right out of the box.
https://imgur.com/a/315ECaf
The outboard CV looks like the grease is way too stiff and there is way too little of it (but, what do I know??).
I am going to put MEISTERSATZ CV grease into the outboard CV joint and hope for the best.
https://imgur.com/a/tsXVkTL
The problem is, this CV joint fits the definition of “stiff” as outlined in the Factory Service Manual under the heading, “Driveline Vibrations.”
If I am missingsomething, someone please clue me in
Last edited by bumpdraft; 07-03-2021 at 05:42 PM. Reason: Which axles do S-Series Drivers recommend ?
Old 07-04-2021, 05:51 PM   #6842
El_bell
El_bell is on a distinguished road
El_bell's Avatar
Painted the door pillar trim black this past week. I’m pretty sure this piece was originally supposed to have some amount of gloss to it if the back side is anything to go by. Used some basic Rustoleum primer and gloss black paint. I didn’t clear it cause I was feeling kind of lazy, so hopefully I don’t find a bunch of little chips developing in the paint over the next week.
File Type: jpg 22C0F3F8-6E65-4E5F-9BFD-1C5DE6647034.jpg (138.5 KB, 26 views)
El_bell is offline   Reply With Quote
Old 07-05-2021, 08:41 PM   #6843
rtfm17
rtfm17 is a jewel in the roughrtfm17 is a jewel in the roughrtfm17 is a jewel in the rough
1999 SL1
A/C flush and fill on both 02 SL2s, new tires for one.
rtfm17 is offline   Reply With Quote
Old 07-05-2021, 08:48 PM   #6844
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Replaced the air bag/computer module that fits under the dash board. Thanks to cgg17 for sending it. Now driving with a functioning air bag system for protection.
A2Saturn is offline   Reply With Quote
Old 07-07-2021, 09:05 PM   #6845
dummo
dummo's Avatar
1997 SW2
Torque wrench check on all four wheels after getting two new tires and a rotation at Town Fair Tire (New England area tire chain store) over a week ago. Good thing I did because the driver's side rear wheel had two loose lugnuts. One rotated over 540 degrees before hitting the wheel.
This just reaffirms the validity of my do-it-yourself attitude.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Old 07-19-2021, 06:10 PM   #6846
Pitcher
Pitcher's Avatar
My 1998 SC2 5-speed Red Hot is still running GREAT!!
10w-30 Rotella Diesel Oil + ext length oil filters
Gets Professional Wax & Sealants (being a Car Detailer)
ANDDDDDDD.........
You won't believe what SC2 I'm buying in a few days.................
Owned 4 other S-Series.
Old 07-19-2021, 08:47 PM   #6847
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
A much much needed throttle body cleaning thanks to the vids of Richpin. Feels smoother already. Currently at 132,500 and approaching my 3 year anniversary of ownership.
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2007 Subaru Forester LL Bean Edition
Previous:
2008 Honda Accord EX-L 2.4
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 07-20-2021, 02:23 PM   #6848
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
1999 SW2
Got an alignment done after changing both wheel bearings - I actually had to bring it to two different shops. The first guy broke the alignment machine and the second shop got it correct.
They both suggested camber bolts but were unaware that the lower strut bolt is adjustable.
'97 Saturn SL2 @ 146k (M. swapped) - In storage, awaiting an engine rebuild
'99 Saturn SW2 @ 92k (M. swapped) - Daily Driver
r/Saturn_Cars moderator
jpsuli is offline   Reply With Quote
Old 07-20-2021, 05:11 PM   #6849
dummo
dummo's Avatar
1997 SW2
I like your early 90's geartooth wheels on your 99 wagon. Well done!
...and nice rack by the way!
Old 07-20-2021, 06:15 PM   #6850
El_bell
El_bell's Avatar
My exhaust heat shield fell off (again) and my go to fix for that problem a hose clamp. Worked pretty well on 2 other spots but this one wasn’t quite able to stop it from rattling. Cut of a chunk that I wasn’t able to hold up with a hose clamp and now the rattle it gone.
My center exhaust mount also broke off…I don’t have an easy way of fixing that so I’ll probably just leave it as is and hope nothing worse comes from it.
Old 07-20-2021, 08:05 PM   #6851
trottida
trottida's Avatar
Get the exhaust hanger fixed as it will stress your mid-pipe and it will eventually crack. An exhaust shop will weld a new one on in a few minutes. I wouldn't be surprised if they sent you out the door with no bill.
1999 SL2 MT (298,000 km @ 06/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 07-22-2021, 10:12 AM   #6852
El_bell
El_bell's Avatar
Hanger fixed per trottida recommendation. Your bill estimate was only off by $10
File Type: jpg 89D3D772-F127-4864-B3A3-3A8C922EEF06.jpg (139.7 KB, 21 views)
Old 07-22-2021, 11:35 AM   #6853
trottida
trottida's Avatar
That's $10 well spent!
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 07-23-2021, 05:23 PM   #6854
El_bell
El_bell's Avatar
Brought it down to the local tire shop to have 2 valve stems swapped out. For some reason, they put 2 long stems with 2 short stems when I got new tires a few years ago. Only noticed when I got some red valve stem caps and 2 where poking out way to far.
I never like going to this tire shop cause they always seem to screw up at least 1 thing up every time I go. I had a feeling they would do this for free though so I went anyway. The streak of bad experiences continues because this time they almost lost one of my new valve stem caps, and completely forgot to put the lug nuts on the front passenger side wheel before sending me off…You can probably imagine how that went.
Old 07-28-2021, 10:54 AM   #6855
bumpdraft
bumpdraft's Avatar
1998 SW2
Getting ready to install a Cardone remanufactured O.E. driver’s side axle
This axle seems smooth and there is no trace of backlash.
Voiding any warranty, I checked the amount of grease:
https://imgur.com/a/ud4mVad
Old 08-04-2021, 10:31 PM   #6856
Bob243
Bob243 is on a distinguished road
Bob243's Avatar
1991 SL1
Fixed the AC in the 95. Ended up just leaky valve cores in the low and high side. Added dye just in case.
Bob243 is offline   Reply With Quote
Old 08-05-2021, 12:38 PM   #6857
bumpdraft
bumpdraft's Avatar
1998 SW2
Today, I installed the 60-1271 axle, after adding more CV grease to the outer and inner boots. Time will tell if that was wise.
Axle Installed: https://imgur.com/a/txxMMYx
The axle that I removed was an aftermarket axle and it failed by becoming loose at the inner CV joint, located next to the transmission. The outer CV joint seemed fine.
Old 08-10-2021, 12:23 AM   #6858
jpsuli
jpsuli's Avatar
1999 SW2
103k oil change
Old 08-15-2021, 11:23 AM   #6859
Eschmitt
Eschmitt is on a distinguished road
2002 SL1
I had a cracked coil spring on the front driver side strut so I replaced both struts upfront.
The front passenger side wheel bearing was showing signs of wear and the hub was in rough shape so I pressed in a new bearing and a new hub.
Also changed the fuel filter
Eschmitt is offline   Reply With Quote
Old 08-16-2021, 06:08 AM   #6860
V3DT
V3DT will become famous soon enoughV3DT will become famous soon enough
The cradle subframe is pretty rotted right under the stabilizer bushing for some reason, so I made a reinforcing plate
didn't weld it because the mounting holes still seem sound, torqued to 103 ft-lbs, at least the bushing isn't slowly sinking into the frame anymore.
Also packed anti-seize lubricant between the plate to see if it will help keep the subframe from rotting more.
V3DT is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
