Old 11-20-2016, 11:19 AM   #1
firstgen67
firstgen67 is on a distinguished road
Default 2002 L200 2.2L thermostat replacement
I am new to this site and I did some searching but couldn't find any info on my exact issue. My 2002 L200's fan has been running the entire time the car is running. Along with the fan, there is a P0128 code that comes up. I did find someone who posted about this on a 2003 L200, however, I don't know if the thermostat is in the same position on my 2002 as on a 2003. I looked under the hood and can't seem to find the thermostat housing where the directions for the 2003 show it. Is there a walk through somewhere on this site for a 2002 or am I just blind and it is in the same spot as the 2003?
firstgen67 is offline   Reply With Quote
Old 11-20-2016, 02:51 PM   #2
billysvue
Default Re: 2002 L200 2.2L thermostat replacement
It's down low and behind the engine/near firewall. NOt an easy job, a knuckle buster.
QUite a few Ytube vid's on the Ecotec t/stat
https://www.youtube.com/results?sear...tec+thermostat
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 11-20-2016, 10:54 PM   #3
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
I found the thermostat to be very easy to change on this engine. You don't even need to remove some of the stuff that the manual says to. I don't think it took more than an hour, including draining a bit of coolant and re-filling. One hint - use a 1/4" drive with the socket on a long extension from above. If you try to go in from the side it doesn't work well. I left the t'stat housing connected to the hose. There is enough flexibility to just move the housing away from the t'stat and pop it out. Note, mine is a manual, and the engine is 2" forward from an automatic, so there may be more room in this case.
Old 11-21-2016, 06:20 PM   #4
pierrot
pierrot's Avatar
redundant
350K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. I fear that I will be correct. I'd rather be wrong.
Old 11-21-2016, 06:25 PM   #5
pierrot
pierrot's Avatar
Welcome to SaturnFans!
P0128 - ECT BELOW THERMOSTAT REGULATING TEMPERATURE (from the 2000 L Series L61 FSM)
Possible causes
*Thermostat stuck open
*Cooling fans always On
*Very low ambient temperatures
*Corrosion in connector or resistance in wiring
*Skewed sensor
The thermostat is in the same location for all ECOTEC 2.2L engines. billysvue's description of its location is correct (although I would drop the "firewall" portion of it). Note that you need to drain the cooling system before removing the water outlet ("thermostat housing" to some) including the water pump drain at the firewall side of the engine. Failing to drain that location will result in a very messy clean up. If you need informaton about how to perform any part of this repair then send a p/m with an email address and I will forward it to you.
BTW, do you have a repair manual of any kind for the car?
2002 Saturn L200 dashboard lamp (light bulb) replacement don2737 L-Series Tech 18 12-19-2017 07:35 PM
Radiator drain/replacement and Thermostat Replacement jeanne17 S-Series General 8 05-18-2010 08:48 PM
2002 L200 - Side View Mirror Replacement snam L-Series General 2 02-13-2010 10:15 AM
2002 L300 Thermostat Replacement azsaturn2 L-Series General 0 12-03-2006 10:22 PM
BCM replacement on a 2002 L200 greyshep L-Series General 6 12-02-2005 09:29 PM
