Old 09-25-2009, 12:31 AM   #1
adventureoflink
adventureoflink's Avatar
Default Light issues.
1997 Saturn SL2, 141k miles
that said, every time I brake, my left light turns on, but my right one doesn't come on unless I turn on my console lights. This sane bulb was replaced in march of this year.
My headlights, brights, and DRLs will point at everything else EXCEPT the road. These have even been known to point at 2nd story windows and high trees
any idea(s) here? Is my alternator getting ready to die
thanks!
Old 09-25-2009, 01:41 AM   #2
elitemarksman
elitemarksman is on a distinguished road
Default Re: Light issues.
Headlights pointing at the wrong place is an aiming issue. There should be screws on each of the headlight assemblies to adjust their aim.
elitemarksman is offline   Reply With Quote
Old 09-25-2009, 11:16 AM   #3
Was your car in an accident? Aim isn't normally that bad off unless the whole assembly was removed and replaced.
For the brake light, the light comes on and gets bright with the brakes only if the headlights are on? Pull the tail light assembly out and check the wiring... compare it to the side that works. Sounds like the PO removed the base and put the wires back on wrong.
Old 09-25-2009, 01:28 PM   #4
adventureoflink
Default
yes, I rear-ended someone almost two years ago however I thought I only took off my deer whistle and scratched the paint
or if my dashboard lights are on, yes.
will do. Although to be fair, I remember the replaced light was working till recently.
Old 09-25-2009, 01:55 PM   #5
adventureoflink
UPDATE:
I put in a new bulb, however, my left signal was COMPLETELY dead. So I screwed with the left side and all is well with the brake lights, for now.
ABS Light / Battery Light Stays ON + starter issues 97 SL1 IanDorety S-Series General 3 08-25-2009 11:08 PM
interior light issues UPSGUY Ion Tech 9 04-11-2007 02:39 AM
Dome light issues milnimi S-Series Tech 5 02-17-2007 01:06 AM
Fog light issues SaturnBaby2 S-Series General 1 10-02-2004 07:10 PM
Airbag light issues 1994SL1 Miscellaneous Tech 4 01-14-2004 11:25 PM
