Old 11-28-2010, 07:56 PM   #1
Sevillian273
Sevillian273 is on a distinguished road
Sevillian273's Avatar
2001 SL2
Default PCV Airflow
While the 2001 SL2 was running I popped the PCV valve out of the grommet to take a look at it and I noticed strong air pressure coming out of the hole in the valve cover. ???
It doesnt smell like exhaust but it does seem to 'pulse' with the engine kind of like the air output of a belt driven smog pump. Is this normal?? 100K miles on engine.
Sevillian273 is offline   Reply With Quote
Old 11-29-2010, 08:54 PM   #2
kaptnjack
kaptnjack will become famous soon enoughkaptnjack will become famous soon enough
kaptnjack's Avatar
1995 SW2
Default Re: PCV Airflow
cant answer your question but I am searching for PCV info too.
mine is full off fresh oil and seems to be sucking oil out of the motor
92 SL2 A/T white
93 SL1 man burgundy
93 SL2 A/T turquoise
94 SL1 man medium blue
94 SL2 A/T gold
95 SW2 A/T white (daily driver)
97 SL2 A/T gold
99 SW1 A/T green
95 SW2 man gold
kaptnjack is offline   Reply With Quote
Old 11-29-2010, 08:57 PM   #3
That is the way they work. As the engine wears you get more blowby and it ends up in the crankcase. These blowby gases are exhausted through the PCV system.
Old 11-29-2010, 09:30 PM   #4
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
Default MY PCV ?'s
Couldn't that pulsing also be caused (at least partially) by the travel of the pistons, e.g., the movement of crankcase air on the non-business side of the pistons? Or do those cancel out among the 4 pistons?
Also, air pollution aside, what would happen if one were to disconnect and plug the PCV vacuum source, and vent the crankcase to atmosphere (with perhaps a filter to minimize oil fouling of the engine compartment). Wasn't this the way it was done prior to PCV?
Thanks!
Baron5867 is offline   Reply With Quote
Old 11-29-2010, 09:33 PM   #5
The average outflow is blowby and the pulsing is caused by the action of the pistons.
Yes, the original approach was to vent the crankcase through a wad of coarse steel wool to the ground. Went away with the 1964 model year. It did keep the center of the road well oiled though.
Old 11-29-2010, 09:37 PM   #6
One thing I've yet to find out with the bypass setup some people install in the PCV line is...what do you do with the oil that goes into the catch-can?
All well & good it's not being burnt anymore, but if you don't/can't put it back into the oil system how does it save anything?
Old 11-29-2010, 09:56 PM   #7
You can dump it back in the engine if you want.
Old 11-29-2010, 09:59 PM   #8
hholbein
1997 SW2
How about adding the catch can's oil to the jug you plan on using to recycle your next oil change draining?
Old 11-29-2010, 10:24 PM   #9
If you use the jelly jar / small Mason jar option, as some do, you can simply put a standard lid on it and label and sell it as blackstrap molasses.
Airflow Rate Fox Slaughter S-Series Mods 17 01-14-2009 08:47 AM
Experimented with airflow a bit... saturnd00d 2008 Vue 7 06-15-2008 10:23 AM
Airflow charts jentzsch23 Ion Tech 0 03-04-2007 10:59 PM
Comfort Airflow to Low? rideox4 S-Series General 3 06-18-2006 08:00 PM
airflow through a/c vents LDB_2001SC2_#54of99 General Saturn Discussion 1 07-31-2000 09:16 AM
