Old 09-26-2008, 05:32 PM   #1
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default Headlight won't adjust down
I have a '96 SC2 and it seems the right headlamp won't adjust down very easily. I've turned the bottom screw quite a bit but it doesn't seem to be moving down very much (if at all). The left lamp I adjusted and accidentally pointed it to the ground (from 25ft away).
Anyone else have this problem before?
Right now my low beams are pointing out where my high beams should be and my high beams are lighting up the trees overhead.
I just got some Sylvania Silverstars (sooooooooo awesome) and I desperately want them adjusted correctly.
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline   Reply With Quote
Adjust Pop Up Headlight Movement Techpriest S-Series General 6 03-30-2013 08:32 AM
How to adjust headlight beam? Spartus S-Series Tech 8 07-08-2008 10:53 PM
anyone know how to adjust the clutch 94503 S-Series Tech 7 10-06-2007 07:00 PM
How do I adjust headlight angle on 95 coupe? zallen777 S-Series Tech 6 01-11-2005 10:01 PM
How do you adjust timing? BobDobbs S-Series Tech 9 01-31-2002 01:47 PM
