Old 09-15-2008, 05:37 PM   #1
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default need a short shifter boot
I have an SPS short shifter and I've had two boots eaten up by it. In time part of the boot will get stuck and pinched when shifting into 4th and sometimes other gears. The first boot I used was the stock shifter (which was a little tattered to begin with) and the second a black "carbon fiber" textured one I got from pep boys (lasted a bit longer).
I was thinking a neoprene boot would work but haven't found any yet. What do you guys w/ short shifters use or recommend?
Thanks!
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline   Reply With Quote
Old 09-15-2008, 06:12 PM   #2
Default Re: need a short shifter boot
Pull the knob off, remove boot, take to old time shoe store, have shortened.
Old 09-15-2008, 06:31 PM   #3
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
I got the idea from someone on here. Pick up the rubber shift boot from the auto parts store. Pull off the console around the shifter. Turn the boot UPSIDE-DOWN and put it on the shifter. Put the console back on, and a cool shift knob. I got a solid chrome knob that uses a set screw to hold it. The guy I got the idea from said that the shaft is the same diameter as a Corvette, so he used a tap and die set (I don't remember what size) to thread the shaft, then ordered a knob made to fit a Corvette shaft.
Here's mine.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
quiksc2 is offline   Reply With Quote
Old 09-15-2008, 06:37 PM   #4
sps SOHC
sps SOHC's Avatar
That's a pretty neat idea quiksc2. I was thinking about using one of those but I wasn't sure how to make it work or what it would look like.
Old 09-15-2008, 06:40 PM   #5
quiksc2
quiksc2's Avatar
I thought about using a piece of sheet metal to make a gated shifter, but the pivot point is so high on the shifter that it wouldn't be much of a gate...
DCS
Short Throw/Short Shifter? Elementkng20 Ion General 0 05-12-2009 12:52 PM
FS: 91-02 S Series Short Throw Shifter & AEM Short Ram Air Intake dacuda Classifieds 0 06-10-2006 07:39 PM
Shifter Boot michelle.luna76 S-Series General 13 03-04-2006 10:22 PM
Slipping Shifter Boot OllieSC Mods and Performance 1 10-19-2002 09:25 PM
No Shifter Boot OllieSC Mods and Performance 10 08-12-2002 07:40 PM
