#1 |
![]() Join Date: Oct 2006
It seems because of perhaps too much washing the black plastic trim-running board below the doors is starting to fade. Anything I can do to restore the color, maybe a dye or paint? I use that color restorer but you have to reapply it often.
Thanks Peeps. |
#2 | |
![]() Quote:
There is a product called 'Forever Black' that's a 'permanent' dye I've also seen a kit at Wal-Mart made by Bondo by the touchup paint. Worst case, I'd get some primer made for flexible plastic and they make bumper spray paint in a couple colors.. |
#3 |
Try Mother's Back to Black too, it works well for some of those areas below the bumper on my '06. i replaced those grey rocker panels with the running boards though........
-sXe for life- Former Saturn owner but still a Saturn Fan~! 2010 Toyota Tundra SR5, 5.7L |
#4 | |
![]() Quote:
Matt
If God had intended driving to be boring, he would have given us all Toyota's |
#5 |
yeah i use it every time i wax. i just waxed the Binkymobile yesterday and put the Back to Black on the pieces underneath the bumpers as well as the black plastic B-pillar and mirror trim, in addition to the rear bumper and running board step pads. There isn't as much grey plastic on the '06 and '07 models, but of course that means there's a lot more painted surface to keep clean and waxed! XD
#6 |
#7 |
Some more thinking...
Back to Black is a good product, but really doesn't excel in the restoring department (nothing really does short of dying) A couple of non-dye items that 'may' help, but aren't so easily obtained at Mother's: Black Again Poorboys Trim Restorer |
#8 | |
![]() ![]() ![]() ![]() Join Date: Apr 2006
2006 VUE Red Line
2007 SKY
![]() Quote:
I've used Adams VRT (Vinyl Rubber Tire Dressing) It enhances and protects rubber. It's water based and does not leave a greasy film.
2006 Black VUE Red Line - Now running iOS 14.7 beta |
#9 |
![]() Join Date: Oct 2004
You will think this is crazy, but it works....
First wash the grey rough pastic well, make you get everything off, make it super clean. Then buy some peanut oil, it is cheap, then get about a 1.5" wide new paint brush, get a cup, pour in the oil and apply the oil to the surface with the brush, it will drip so make sure you are in an area where this is not a concern. Let it sit for 10 min then wipe off with old clean rags. The plastic will look better than new and the bugs and crap do not stick as much. Old trick but the looks you get with a fresh wax job and impecable plastic mouldings are worth it. Shssssss do not tell owners other than VUE owners.... |
#10 |
Peanut oil is a short term cosmetic fix. It also attracts dust It reminded me of an interesting trim test a person did using several items including peanut oil, olive oil, 303, Back to Black, forever black.and a few others
The peanut oil did look as if it performed better than many products though.. http://www.jwardell.com/mini/2006/09...-have-a-winner. |
#11 | |
![]() Quote:
Cheers, |
#12 | |
![]() Quote:
I'd bet Motor oil would do the same thing as peanut oil On a whim, I used some 1 step tire cleaner/shine on some spots and it looked pretty good. I usually only use it for fenderwells |
#13 |
True, it does attract dust, guess everything has a downfall. I usualy use it when I want to go cruzing after a complete cosmetic job.
It however does not go rancid, I have been using it for years, never had a problem with that. A good pressure washer also gets off all the dust and oil. Someone told me that GM had a fix for all the plastic that was on the avalanche as it is almost all grey plastic at one time, I have not looked into that claim. Have fun! B ![]() |
#14 | |
![]() Quote:
A full kit to restore an avalanche is 162 bucks, but you can pick up the cleaner and a smaller shoe polish type die for considerably less |
#15 | |
![]() Quote:
'Silven' K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues |
#16 |
Bookmarks |
alternator .. black plastic cover broken | elvisthedj | S-Series General | 6 | 02-02-2009 04:50 PM |
98 SL2 - black plastic on door crackling | smalltownjava | S-Series General | 2 | 03-20-2006 11:14 AM |
What to use on maintaining the black plastic parts. | TheDude | Vue General | 27 | 07-15-2005 08:31 PM |
What to use on maintaining the black plastic parts. | TheDude | Vue General | 10 | 07-15-2005 01:07 PM |
That black plastic air deflector... | manualman | S-Series Tech | 14 | 03-21-2002 11:20 PM |
