#1 |
![]() Join Date: Oct 2001
A friend of mine that is into moding out his car pointed out that Jet makes a performance chip for the Saturn L, the web site doesn’t say if it is for the 4 or 6 cylinder engine, but I though I would pass this info on to anyone who is curious. It looks like Jet chips can add 10-20 hp for most cars, but don’t hold me to that. One problem with it though, it requires you to use higher octane gas, I think 91+.
#2 |
read this article. they tested a Jet chip. SPS and SPC dynoed them in the past on S-series Saturns and found no improvement. the L-series is different so who knows?
http://www.caranddriver.com/xp/Caran...keywords=chips
eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe |
#3 | |
![]() Quote:
Guess they're messing with the Spark Timing to make it runs hot....geez! I won't touch this with a 10-feet pole. ![]() |
#4 |
I won't claim to understand how it works, but here is the company web site. It has some explanation to how it works.
http://www.jetchip.com/ |
#5 |
there is a big technical difference between the 4 and the 6 ... but i cant find any mention of saturn period on this site.
#6 |
The site that actually sells the chip is
http://www.nopionline.com/ under the saturn heading |
#7 |
![]() ![]() Is that an OBDII socket connector on the end? http://www.nopionline.com/index.cfm?...gine%20Control |
#8 |
so....who's going to buy one and test it out for us?
#9 |
I noticed they also have one for the SC2. Aside from advancing the timing to use premium fuel is there any other advantage. Also, can you manually advance your timing (say with a timing light) if you already use 93 octane? On my Mustang GT, I advanced the timing to 14 degrees. Anyone know what the optimum setting would be on a SC2?
2006 Ion Redline- GMPP Stage 2 |
#10 |
there's no manual way to adjust the timing on a saturn since there's no distributor to rotate. you'd need something to hack into the pcm to change the timing. or replace the pcm with a tec-2 or motec, etc...
Bookmarks |
performance chip? | SL1_sleeper670 | S-Series Mods | 25 | 12-29-2008 09:13 PM |
Performance Chip | saturnPr!de | S-Series Mods | 26 | 05-13-2006 06:05 PM |
Performance chip | svlplaya | Community Center | 1 | 04-26-2006 08:34 AM |
Performance Chip | KJB | Vue General | 14 | 12-22-2003 04:18 AM |
Performance Chip? | Fat Whacker | Mods and Performance | 4 | 09-15-2001 07:49 AM |
