Old 09-28-2006, 09:37 PM   #1
erick
erick is on a distinguished road
Default 1991 SL1 constant sputter and hesitation
Hi,
The saturns cooling fan broke and unfortunatly I noticed my girlfriend over heated the car, probably ran hot for quite a while. Ever since the car has been continuosly running worse. What could be the problem? I have checked the EGR solenoid, EVAP canister purge solenoid, Coolant fan relay, and A/C relay. I dont know what else it could be? What can go wrong when a car overheats? It is a 1991 saturn SL1 with a SOHC. I have also checked the spark plugs and wires
Thanks
Erick
erick is offline   Reply With Quote
Old 09-28-2006, 10:04 PM   #2
simidrm
simidrm is on a distinguished road
Default Re: 1991 SL1 constant sputter and hesitation
If it got hot enough you either blowed a head gasket or cracked the head,if so it will run better when cold and as it heats up it will get worse as the crack expands with heat,and could be putting anti-freeze into the oil or leaking some down the block from the head,or out the exhaust,or burnt a valve.
Check the compression on all cylinders,they should all be within 10-15 lbs from the highest to lowest reading.
Good luck
simidrm is offline   Reply With Quote
Old 09-29-2006, 04:23 AM   #3
How does the oil look? How does the coolant look?
Old 09-29-2006, 12:19 PM   #4
erick
The oil was a bit low but the coolant is fine. The car runs the same no matter warm or cold. The compression is also good. All spark plugs look the same.
Old 09-29-2006, 08:27 PM   #5
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
Do you have a brass tipped ECTS?
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
JS593 is offline   Reply With Quote
1991 sl1 sl2 drill_bit S-Series Tech 1 06-24-2009 12:36 AM
2001 sl1 constant idle at 4k jivxx S-Series Tech 4 03-10-2008 01:25 AM
2000 SL1 Engine Sputter when Accelerating tc1310 S-Series Tech 2 08-30-2007 02:22 PM
1991 SL1 constant sputter and hesitation erick S-Series Tech 0 09-28-2006 07:42 PM
97,sl1,sohc-cold Sputter On Start BAYFISHER S-Series General 8 01-14-2004 11:12 PM
