Old 09-20-2015, 04:59 PM   #1
gppl
gppl is on a distinguished road
gppl's Avatar
2001 SL2
Default Installing Cruise Control and BCM/PCM
I'm planning on installing cruise control in my 2001 SL2. Swapping the steering wheel and installing the module itself shouldn't be difficult, and it seems like there's a lot out there on doing that. I'm more concerned about enabling it on the computer. I heard that, instead of paying a dealer to reprogram it, I could just swap the PCM to one that already has cruise enabled, would that work?
In addition, if I do have to take it to a dealer for reprogramming, how to I keep things as cheap as possible? Anybody know of any dealers around the Lansing, MI area that will do it for cheap? The former Saturn dealer turned Hyundai closed up, unfortunately.
gppl is offline   Reply With Quote
Old 09-22-2015, 01:28 PM   #2
CZECHLAGER
CZECHLAGER has a spectacular aura aboutCZECHLAGER has a spectacular aura about
2001 SL2
1995 SW1
Default Re: Installing Cruise Control and BCM/PCM
Hello, You might be in luck. This was a couple of three years ago. There was someone on the forum in or near Lansing that went to the GM dealer in Lansing that also owned the Saturn dealership and had it done for free. If I remember right, the GM dealer that is there now took in all the displaced Saturn people back then. So they did have people that knew how to work on Saturns Your car needs to be hooked up to a GM backed server for the cruise to be programmed in and turned on. Good Luck. Rick
CZECHLAGER is offline   Reply With Quote
Installing cruise control Sphere69 Vue Mods 10 08-10-2013 11:09 PM
Installing Cruise Control in 93 SC2 droveavolvoonce S-Series Tech 11 07-10-2008 03:22 PM
Installing Cruise Control Help Zvolen S-Series General 3 03-03-2008 03:25 PM
Installing Cruise Control '95 SL1 - Programing PCM 3danh S-Series Tech 13 01-24-2006 03:55 PM
Installing Cruise Control rosyjazz General Saturn Discussion 15 07-27-2001 03:43 PM
