#1 |
Hi my wife's 03 vue AWD 3.0l 180k has been throwing codes and tripping the ses light. The codes are P0171 and P0174 both are on bank 1. I suspect a dying O2 sensor. Which one is Bank one front or rear?
Any other suggestions are welcome.
marmitage 03 Vue Silver, Daughters 97 SL2 Back from the grave 99 Sw2 Daily driver |
#2 |
![]() ![]() Join Date: Jun 2000
P0174 is bank 2, P0171 Bank 1, When i had these codes this is what fixeds it for me. The upper intake manifold splits in two. when i had this problem i re-secured the top of the upper manifold. ( not the upper and lower manifolds although this should be checked also). Attached pic shows upper been removed from lower. screws on top of upper is what you want to check. There are a lot of things to check . not even sure an O2 sensor is going to help you. usually an air leak problem.
2003 Vue 6cyl 2WD |
#3 |
Thank you sir will check tonight.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
1995 SW2
![]() Quote:
http://www.saturnfans.com/forums/att...4&d=1252287894 Btw marmitage - Bank 1 is Firewall side. |
#5 |
![]() ![]() Join Date: Jan 2014
Just had the same codes on my 03 v6 and it was the throttle body gasket.
#6 | |
![]() Quote:
2003 Vue 6cyl 2WD |
#7 |
Hi
Another thing you can do is spray brake cleaner around any possible leaks and listen for an increase in rpms. people also use propane to find the leaks but i prefer not too.
2003 Vue 6cyl 2WD |
#8 |
I used starting fluid to find my leak. They sell it at Walmart.
#9 |
That will work.
2003 Vue 6cyl 2WD |
Bookmarks |
throwing codes ! | jaysan | Vue General | 6 | 02-25-2015 10:57 AM |
Throwing two codes | bczracecar | S-Series Tech | 1 | 06-27-2013 10:44 AM |
Throwing some codes after new coils | DuffyDidIt | S-Series Tech | 14 | 02-24-2013 10:01 PM |
97 sc2 throwing codes | red87tll | S-Series Tech | 1 | 08-03-2007 09:32 PM |
Throwing codes 23 35 45 | JS593 | S-Series General | 9 | 01-05-2006 12:11 AM |
