Old 07-03-2012, 01:41 PM   #1
alinta1970
alinta1970 is on a distinguished road
Default 2002 L200 security light on and hard start
So I go out to my car today to start it and its turning over but very slowly and finally started then the security light came on and stayed on. I shut the car off and pulled the key out and put it back and the car started no security light. I get to the store shut the car off and when I came back out it was hard to start the security light came on but went right off. What is the issue?
alinta1970 is offline   Reply With Quote
Old 07-03-2012, 02:56 PM   #2
Default Re: 2002 L200 security light on and hard start
This is a mixed bag of possible security problems but nothing major, yet. The only thing wrong is the security light staying ON after the engine is started and running; this means the factory Passlock theft deterrent system has detected an internal failure and disabled itself while alerting you that its broken by leaving the security indicator ON while the engine runs. Usually this means a trip to GM but it resets itself the next time the ignition switch is turned to the START position with the engine starting and security staying off - the normal start up procedure. This may be electronics and may not.
How old is the battery and when was it checked the last time? Battery, battery cables, and alternator issues can cause strange issues if not checked every now and then. Don't allow corrosion to build up on the battery terminals.
2002 L200 security system issue speedy02ls L-Series Tech 5 04-17-2012 09:20 PM
2002 Vue cranks, no start. Security light stays lit. Woodsman Vue Tech 21 12-26-2011 10:49 PM
2001 l200 security light flashing?? help diezilnj L-Series Tech 4 04-06-2010 03:17 PM
2002 L200 security light & odometer LCompite L-Series Tech 5 02-02-2010 12:15 PM
Intermittent Security light- 2002 L200 L4 boomerang86 L-Series Tech 0 08-25-2005 07:44 AM
