Old 03-04-2012, 11:59 AM   #1
sutty
sutty is on a distinguished road
Default 2002 Vue throwing codes p0172 and p1514
I was driving my Vue a few months back and all of the sudden every dash light came on and the power was reduced. I pulled over to check under the hood. Couldn't see anyting obivious. Restarted and nursed it home. There is signifigant engine power loss off the line. I canges spark plugs and oil. very limited driving since.
On to today, I finally went out and bought the innova 3100 code reader. It's throwing codes p0172 and p1514.
Not sure what the problem is or where to go from here. Any ideas?
sutty is offline   Reply With Quote
Old 03-04-2012, 12:07 PM   #2
Default Re: 2002 Vue throwing codes p0172 and p1514
Which engine?
Old 03-04-2012, 12:15 PM   #3
Chazberry
Chazberry's Avatar
1995 SW2
When this happened to me it turned out my Alternator was toast.
Old 11-18-2015, 07:39 PM   #4
TomTom4049
TomTom4049 is on a distinguished road
TomTom4049's Avatar
2003
Dazed Re: 2002 Vue throwing codes p0172 and p1514
I'm working on a friends '03 Vue with the 2.2 and it is setting the same codes P1514 & P0172. It does this if you rev beyond 3200 RPM rolling or sitting still. The throttle response even when it isn't setting the codes is soft and sort of lazy, lacking power in general.
Any have ideas out there?
TomTom4049 is offline   Reply With Quote
Old 11-18-2015, 09:18 PM   #5
ruley73
ruley73's Avatar
P0172 indicates a rich running condition and P1514 basically indicates that the amount of airflow (as detected by the MAF sensor) is too high relative to the detected throttle position. The combination of those two codes points to either a bad MAF sensor or a bad throttlebody (specifically the position sensor that is built into the throttlebody butterfly motor).
You should check the airbox & air intake hose and make sure it is properly closed/tightened, inspect the MAF sensor & related wiring, and inspect the throttlebody wiring.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 216K miles
2018 Chrysler Pacifica Touring L 100K miles
Need help, car throwing plenty of codes Shifted L-Series Tech 4 02-14-2011 01:25 PM
Saturn throwing codes HELP!! bambibuster89 S-Series Tech 4 02-28-2009 01:03 AM
97 sc2 throwing codes red87tll S-Series Tech 1 08-03-2007 09:32 PM
New ECTS, now throwing codes at me!! Tempsho S-Series Tech 27 03-02-2006 07:02 PM
Throwing codes 23 35 45 JS593 S-Series General 9 01-05-2006 12:11 AM
