Old 07-15-2011, 03:29 PM   #1
dancin4
dancin4 is on a distinguished road
dancin4's Avatar
2001 L-Series 2.2L Sedan
Wrench Balance Chain markings at TDC or ?
Hi All,
Thanks for all the help with our 4 Saturn cars.... (2002 SC-2, L200 2.2L, Sl-2.)
I am prepping the L200 Ecotec engine to live longer for my daughter. I have the engine covers off and the crankshaft at 3 O'clock. Now how would I go about removing all the timing chain parts and then get the balance shafts aligned so that everything will work together....The post by Low Saturn has been very helpful. But I don't know how to do the balance chain....
dancin4 is offline   Reply With Quote
Old 07-15-2011, 10:23 PM   #2
born again
born again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to allborn again is a name known to all
2000 L-Series 2.2L Wagon
Default Re: Balance Chain markings at TDC or ?
According to Alldata the intake side balance shaft timing mark should point straight up, the exhaust side balance shaft timing mark should point straight down, and the chain is installed with the colored links on the marks with the crankshaft with #1 piston at TDC (crank keyway straight up). The odd colored link goes on the crank sprocket.
Old 07-16-2011, 03:02 PM   #3
dancin4
dancin4's Avatar
Thumbs Up Re: Balance Chain markings at TDC or ?
Thanks, that will help me.
...I will have to "lock the cam gears with the drill bits.
Old 07-16-2011, 08:10 PM   #4
satlite440
2001 SL2
hope this helps..
Old 07-17-2011, 12:52 PM   #5
dancin4
dancin4's Avatar
Thanks,
That helps a ton...diagrams!
Old 07-18-2011, 09:42 PM   #6
dancin4
dancin4's Avatar
Originally Posted by dancin4 View Post
Thanks,
One question...the drill bits how do they fit in or do I have to disassemble more...to me it looks like the head is in the way....
The engine is now at TDC with the key-way facing up and the pistons pushing the straws up to the max height. So then I will start the disassemble of the chains/tension ers and chain guides.
Tags
2001 l200, balance chain, ecotec, timing chain
L81 Timing belt markings? flappytango Vue Tech 24 05-15-2017 12:56 AM
Tire Balance and Alignment AQuinn19 S-Series Tech 20 02-03-2010 02:31 PM
Balance problems? Saturntrip S-Series Mods 2 12-07-2008 07:48 PM
balance shaft chain tensioner -- please help! knightpitt L-Series Tech 4 11-18-2008 10:34 PM
Balance Shaft Help fastcarsspeed L-Series Tech 5 04-26-2007 06:38 AM
