Old 01-08-2003, 06:09 PM   #1
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Sad Leakage!
I'm driving gently down the road and my temp light starts flashing along with my low coolant light. I really really really don't want to deal with this again. Before it happened because my heater core went bad and it was leaking inside of my car and whenever I tried to turn the heat on. So I finally got that fixed (for a big price) and it's been fine since then (about 3 months ago). Now the damn thing is going low and I don't see any leaks anywhere, inside or outside the car. What's the dealio?
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline
Old 01-08-2003, 11:00 PM   #2
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default
How's your rad cap? Could it be steaming away out of it? Can you smell a hint of antifreeze w/engine hot at idle w/the hood open?
Dach is offline
Old 01-09-2003, 08:46 PM   #3
Default
Saturns can seep a good bit from the water pump without leaving an obvious wet spot on the ground. Have a look at the bottom of the water pump through the wheel well (remove the front shield) to see if you can see any dried aniti freeze residue or any wetness.
ssicarman is offline
Old 01-09-2003, 10:32 PM   #4
sps SOHC
sps SOHC's Avatar
Default
ok. I think something maybe wrong with the cap or something because the lights start flashing when it's at the FULL Cold level. I have to fill it a ways above that for it to turn off. Also I don't think I have enough or any antifreeze in there since it was drained when I changed bypassed the heater core. But I'm sure the mechanic put some in there.
sps SOHC is offline
Old 01-09-2003, 11:44 PM   #5
Default
When the engine is cold the level in the surge tank should be at about the level of the seam in the surge tank. If the rad cap is not holding pressure then you can definetely loose coolant through there. The best way to tell is to get the cap pressure tested or just change it, depeneds on which is cheaper. If the cap is not holding pressure then you may be able to see dryed coolant on the surge tank. If the level is at or above the seam of the tank and the light is still flashing you may want to try cleaning out the tank to see if this helps. The level sensor could be sticking.
coolant leakage tgaff L-Series Tech 16 06-16-2010 07:10 PM
Leakage justandgirl S-Series General 3 03-17-2007 08:38 PM
Oil Leakage. 4dhtrs S-Series General 2 01-23-2005 11:20 PM
Battery leakage DaytonaSL2 S-Series General 4 01-12-2005 06:27 PM
Serious water leakage DaggNabbitt Ion General 10 10-27-2004 10:39 PM
