#1 |
![]() Join Date: Jan 2005
Hi,
I've been trying to adjust the parking brake on my '96 SL2. It has ABS and the 4-wheel disc brakes. When I remove the center console, I see two cables leading up to the parking brake assembly. How do I loosen and/or tighten those cables? I see two little "knob" looking devices. Do I adjust those? What tool should I use? Thanks!
'10 Altima 3.5SR V6- 5k '96 SL2- 150k! '92 Previa- 99k |
#2 |
If you have a look at the park brake handle you should be able to see the cable adjuster there.
A lousy day in paradise is still a day in paradise. |
#3 |
He means after you pull the cover off the handle. There's an adjustment nut doodad at the base of the handle.
There is nothing more frightening than ignorance in action. |
#4 | |
![]() Quote:
I noticed that the LR caliper does not release the cable as much as the RR caliper. I guess the spring is just getting weak on that side? Just to be safe, I set the parking brake a tad looser just to make sure the pad won't drag too much during normal use. I have it loosened enough so that I would need to engage the parking brake six clicks in order for the car to not roll in R.
Bookmarks |
Removing the parking brake cable from the park brake lever | turbobuick33 | S-Series Tech | 3 | 12-29-2008 07:32 PM |
97 SL2 Disc Brake Parking Brake problem | 64Pete | S-Series Tech | 8 | 09-02-2007 10:29 PM |
L-series parking brake adjustment | unkle bik | L-Series Tech | 1 | 09-02-2004 10:04 PM |
Parking Brake Cable Adjustment...? | JDub99SL2 | S-Series Tech | 8 | 01-22-2004 10:45 PM |
Parking brake adjustment | JohnS_98 | S-Series Tech | 12 | 08-04-2003 09:49 AM |
