Old 07-07-2008, 04:21 AM   #1
jcrollins
jcrollins is on a distinguished road
Default Key sticks in the lock
My wife's 2004 Ion is experiencing an intermittant problem with the key sticking in the lock. Periodically but not all the time, when we reach our destination, we can't remove the key from the lock. We can turn off the engine but the key will not turn to the position needed to remove it. We have to turn the key to the start position and back several times and eventually you will hear what sounds like a solonoid activating and then you can remove the key. What do I need to do to fix this and how difficult is it to fix on my own.
Thanks in advance for your assistance.
John in Dallas
jcrollins is offline   Reply With Quote
Old 07-07-2008, 07:27 AM   #2
Tethys
Tethys is on a distinguished road
Tethys's Avatar
Default Re: Key sticks in the lock
John,
It sounds like the ignition switch in your wife's car is failing. Use the search feature on this board to read other posts, many other posts, about how others solved this common Ion problem, including me. It happened to me last July - I couldn't turn the car off or remove the key. The car had to be towed on a flatbed truck to the retailer, where the the ignition cylinder was replaced and the new security system, Passlock, had to be "relearned" by the new cylinder so I could drive the car.
Good luck.
2015 Buick Verano Turbo
5 - 2006 Ion 3 Sedan, Manual, Storm Grey
4 - 2004 Ion 2 Sedan, Manual, Electric Blue
3 - 1996 SL2 Manual, Medium Red
2 - 1991 SL1 Manual, White
1 - 1991 SL Manual, Grey
Tethys is offline   Reply With Quote
Old 07-08-2008, 02:21 PM   #3
davesaturn
davesaturn is on a distinguished road
http://www.saturnfans.com/forums/sho...d.php?t=118963
I hope this helps
davesaturn is offline   Reply With Quote
Door Key Lock NorthernIon General Saturn Discussion 1 09-10-2006 11:08 PM
02 SL2 Auto Key sticks in Ignition till I bump Shifter up. actnbill S-Series General 5 04-01-2006 10:08 AM
Replacing key lock dansl2 S-Series Tech 7 08-26-2005 01:53 PM
Ignition lock sticks 99 SL2 S-Series General 5 08-09-2005 08:40 PM
Key Lock: Have you had yours? AZguy L-Series General 12 04-13-2005 09:47 AM
