#1 |
1, Is there a way to add grease to a wheel bearing using a needle attachment on a grease gun?
And 2, can I use grey moly bearing grease to grease the clutch gear linkage? Cheers!
The bureaucracy is expanding to meet the needs of the expanding bureaucracy. |
#2 |
![]() Join Date: Jan 2007
1997 SC1
I have no experience with the "Saturn" bearings, but I do with other GM front drive cars, and you can't add grease to any of the front ones. If you tried I think you would, at best, poke a hole in a seal that then might leak. If there's a problem with a wheel bearing its best to just replace it as they are sealed and can't be serviced.
#3 | |
![]() Join Date: Jun 2006
![]() Quote:
I have used a needle on other bearings but never tried it here and also the last grease you want to use in a wheel bearing is something moly based. (moly and roller bearings do not mix well) |
#4 |
On the first question I think not.
On the second, it's a hydraulic clutch, what are you thinking about greasing???
There is nothing more frightening than ignorance in action. |
#5 |
Since you guys are talking about wheel bearings. Does any one know what size the axel nut is on a 97 SC2?I think its a 28mm but I am not sure? thanks in advance.
#6 | |
![]() Quote:
On #2, I want to grease the linkage shaft below the air intake and to the left of the transmission dipstick. I sprayed some cleaner on the dipstick and I think i got some on the linkage removing some grease. I want to add some back. I figured I could do that with a needle attachment, but I'm not sure the grey moly grease is ok for that. I used the grey moly in the tie rod ends, but I don't know if it is applicable for this. Haynes recommends greasing the linkage regularly, but doesn't specify how or what to use.
#7 |
The shift cables. I use lithium grease but, I wouldn't think it would matter much on those.
#8 |
Moly grease has little bits of moly in it and it is great for ball joints, tierod ends and slip joints but deadly to bearings. I personally do not think the needle greasing is a bad idea only the choice of grease.
#9 | |
![]() Quote:
Could I use white lithium grease in a spray can? I bought some, similar to wd40, but spray-able lithium grease.
#10 |
I have some of that. You must have been to Harbor Freight. It should work fine.
#11 | |
![]() Join Date: Apr 2006
2006 ION-2 Sedan
![]() Quote:
Interesting. Motor oil has moly in the additive packages. Havoline especially has a decent amount of moly. Why isn't the moly harmful to the bearings inside a motor? |
#12 |
I've been on BITOG before so I can answer that. Oil has special additives to keep the moly suspended in the liquid. Grease doesn't.
#13 |
2006 ION-2 Sedan
#14 |
![]() Join Date: Jun 2002
Both front and rear bearings on a S-series do not require maintenance. If they are bad, just replace them.
85 GLH 367whp. http://www.saturnfans.com/forums/showthread.php?p=2261629#post2261629 00 Insight 72mpg |
#15 |
30mm for the axle nut i believe
1996 Dodge Avenger ES: 2.5L V6 |
#16 |
Not only that the clearance in a engine are generally a lot bigger than a roller bearing under extreme pressure and there is no "film" thick enough to safely suspend them without damaging bearings. Production tolerances in a good roller bearing makes engine tolerances look very very sloppy.
Bookmarks |
Wheel Bearing? | tmthomp | L-Series Tech | 10 | 04-20-2009 09:33 PM |
Wheel Bearing I think | maximuscrates | S-Series Tech | 18 | 01-09-2008 12:57 AM |
white lithium grease can be used as brake caliper grease? | microsat | S-Series General | 9 | 09-18-2007 03:19 PM |
Heard good to replace CV joint grease @50K | linuxdude | S-Series Tech | 6 | 04-15-2007 03:01 PM |
Wheel bearing #? | '98GoldSL1 | S-Series Tech | 5 | 11-04-2006 03:59 AM |
