Old 05-17-2011, 12:01 PM   #1
dm919
dm919 is on a distinguished road
Default I debonged my 3.5!
I wish I had done this a long time ago! I just made the last payment a few weeks ago and I didn't want to start doing anything to it until it was paid for. Its barely noticeable until you really wind it up. You should see the look on people's faces when you hit it with their windows down It wasn't a real pain in the arse, but I did have to get the Sawzall out and cut away at it. I just removed the passenger headlight-I really didn't feel like taking the bumper off. It only took about 45 minutes from start to finish. Here is a video of what it sounds like:
http://www.youtube.com/watch?v=A5uVZKtk_Xs
dm919 is offline   Reply With Quote
Old 05-17-2011, 02:43 PM   #2
Macsleuth
Macsleuth is on a distinguished road
Default Re: I debonged my 3.5!
What does debonged mean?
Macsleuth is offline   Reply With Quote
Old 05-17-2011, 04:09 PM   #3
Hoagrod
Hoagrod is on a distinguished road
Hoagrod's Avatar
2006 VUE Red Line
Can you post a picture of where you cut the bong to remove it? I had trouble with this a few days ago. Kind of nervous to cut it up. So when the bong is removed you just leave that big hole in the bottom of the OEM air box open?
2006 Vue RedLine.
Hoagrod is offline   Reply With Quote
Old 05-17-2011, 04:10 PM   #4
djb383
djb383 is on a distinguished road
djb383's Avatar
Don't stop with the de-bong...finish it up with true ram air.
http://www.saturnfans.com/forums/sho...rammed+chillin
djb383 is offline   Reply With Quote
Old 05-17-2011, 07:23 PM   #5
dm919
I already threw the pieces out that I cut. There wasn't any real rhyme or reason-I just made sure not to cut foglight + headlight wires! And yes there is just a big hole at the bottom of the airbox, but that's why it sounds so awesome! I will just have to check the air filter a little more often now.
And djb383, I can't do the ram air system you are referring to-I have factory fog lights
Old 05-17-2011, 09:08 PM   #6
djb383
djb383's Avatar
Originally Posted by dm919 View Post
........And djb383, I can't do the ram air system you are referring to-I have factory fog lights
Yep, ours has factory fogs too, the ram-air intake is behind the grille........review the pics.
Old 05-17-2011, 10:57 PM   #7
dm919
Oops-I was looking at the pics on my teeny tiny Blackberry screen. I think I am going to leave it like it is. That setup looks like it would just needlessly draw water up into the intake.
Old 05-18-2011, 08:21 AM   #8
djb383
djb383's Avatar
Default
No problems for 5 years now. Water has a tendency to not run uphill.....u do need to clean bugs off the filter element as ram-air works quite well.
Old 05-18-2011, 11:07 AM   #9
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I've been debonged for........ 6, 6.5 years or so. Driven through many midwestern downpours, even through water up to the running boards (slowly) and haven't had any water ingestion issues.
Not a Saturn.
Old 05-18-2011, 11:14 AM   #10
djb383
djb383's Avatar
Default
.......and the factory filter box has holes in the bottom for drainage. Isn't the whole idea about more/cooler air? I just thought it was a good way to maximize de-bonging......took it a step further.
Old 05-18-2011, 03:53 PM   #11
pyroom
pyroom is on a distinguished road
pyroom's Avatar
2004 VUE 3.5L
You need to pretty much submerge the throttle body in water before an engine will hydro-lock.
I took this a step further and heat-wrapped the tube that goes over the engine. Didn't reduce the intake temp at all, but it kept the heat from building up when stopped in traffic a bit.
2004 Vue 3.5L AWD
pyroom is offline   Reply With Quote
Old 05-18-2011, 05:18 PM   #12
djb383
djb383's Avatar
Default
IIRC, after I did the ram-air, intake air temp dropped to almost ambient temp while crusing. Before ram-air, intake air temp was something like 25+ degrees higher than ambient, again, while crusing. Not much difference moving slow/stopped.
Old 05-18-2011, 08:29 PM   #13
pyroom
pyroom's Avatar
2004 VUE 3.5L
I have the K&N filter & some 5" pipe directing air straight from my fog light inlet to the filter. When cruising, I notice the temperature is a constant 13 degrees hotter than the outside temp.
2004 Vue 3.5L AWD
Old 05-18-2011, 09:29 PM   #14
djb383
djb383's Avatar
Default
Is the K&N metal? Absorbing heat?
Old 05-18-2011, 09:52 PM   #15
pyroom
pyroom's Avatar
2004 VUE 3.5L
Yes, it's wrapped in insulation though.
2004 Vue 3.5L AWD
Old 05-18-2011, 11:10 PM   #16
djb383
djb383's Avatar
Hummm, could '04 vs '06 intake air sensors be located differently? I don't know.....but that was about the 1st thing I noticed, how much closer to ambient temp the intake temp was......like <5 degrees above ambient when at speed.
Old 05-19-2011, 12:07 AM   #17
pyroom
pyroom's Avatar
2004 VUE 3.5L
K&N does relocate the sensor to further down the line from the filter. Your ram air probably blows right onto the sensor, as mine has to make a bend before it reaches the sensor.
If you feel the air inside the heat shield, it's much colder than the air in the engine bay. Tomorrow I'm going to bypass the throttle body coolant hose and possibly order some Phenolic spacers.
If K&N claims 11hp, I wonder how much your getting from your $14.00 setup.
2004 Vue 3.5L AWD
Old 05-19-2011, 01:57 AM   #18
Shadow_tek001
Shadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of light
Shadow_tek001's Avatar
Mine sounded pretty much the same, with the CAI. But now without the mid-muffler, it sounds even more throaty.
Edward.
Shadow_tek001 is offline   Reply With Quote
Old 05-19-2011, 11:53 AM   #19
djb383
djb383's Avatar
Default
Do u still have the stock mid-muff? Can u post a pic taken from one end looking in?
Old 05-19-2011, 12:07 PM   #20
Shadow_tek001
No, I've thrown it out. But i can describe it quite easily, it was straight through, about a 1/2 narrower then the rest of the system, looked like a chease grater on the inside (that many holes). Other then that, nothing else interesting about it.
Edward.
