Old 07-16-2017, 01:01 PM   #1
jarluk
jarluk is on a distinguished road
Default 2009 Astra Diagnostic Error Codes, diagnostic help needed
I have these 4 error codes, vehicle was stuttering at low rev's and had check engine light on.
P0300
P0301
I have changed spark plugs to help with this but no change in performance
P0313
C1555
What are these codes? What is recommended course of action?
Should I invest in a new iginition coil pack?
jarluk is offline   Reply With Quote
Old 07-16-2017, 01:57 PM   #2
Default Re: 2009 Astra Diagnostic Error Codes, diagnostic help needed
P0300 is a general misfire for all four cylinders, P0301 is for misfiring in cylinder #1. If you search past threads within the Astra forums, you may see a repeating failure pattern of coil packs.
Googling for each error code will provide many sites with code definitions.
Old 09-05-2017, 04:58 PM   #3
DWW
DWW has a spectacular aura aboutDWW has a spectacular aura aboutDWW has a spectacular aura about
My daughter has a 2008 XR that has thrown a number of codes including 300, 301 and 313. I have replaced plugs, coil pack, mass airflow sensor and air filter. Car runs great but the CEL was still on. I recently (this past Saturday) cleared the codes and am waiting to see if the CEL comes back on.
DWW is offline   Reply With Quote
Old 11-10-2017, 12:46 PM   #4
j.small17
j.small17 has a spectacular aura aboutj.small17 has a spectacular aura aboutj.small17 has a spectacular aura about
2009 Astra XE
My 09 Astra XE is giving me 0301 and 0313 codes. Running very rough, acceleration is weak, and CEL comes and goes as I drive. Based on a few threads I've read on this site (it's been a big help for me, a new Astra driver) I figure it's either the spark plugs or ignition coils.
I replaced the spark plugs first, to see if that helps at all. The gap was bigger than .045, so I tried closing the gap (didn't help) then I put in new plugs (didn't help either).
Now, I have ordered an aftermarket ignition coil pack (Spectra Premium C-828 from eBay, also avail on Amazon.ca). It should be here in about a week. Will update when it's installed. Hopefully it gets everything back to normal!
Edit: forgot to mention some details on my car. Just purchased in July from a used dealer. 54000 km on it (up to 59K now) and drove like it was brand new. It may have been sitting for a while (lug bolts were INCREDIBLY difficult to get off to change to winter tires and the oil drain plug is seized/stuck) before I bought it.
j.small17 is offline   Reply With Quote
Old 11-10-2017, 08:04 PM   #5
P0301 is a misfire in cylinder#1 while P0313 is a misfire detected with low fuel; https://www.engine-codes.com/p0313.html. Astra members here may have better info. Did you run the fuel tank to close to empty?
Whoever did the wheels and oil may have used gorilla techniques using a pneumatic impact wrench set for 3 million ft-lbs.......... Morons do this in laziness instead of learning what t-o-r-q-u-e [tork] means and using finesse if they insist on using pneumatic impact tools.
Old 11-18-2017, 06:19 PM   #6
j.small17
2009 Astra XE
Update: Ignition coil pack arrived yesterday and I installed it today. Car runs smooth and is good as new!
Re: drain plug - it seems like it was just over tightened. Was able to get it off with some TLC from a heat gun and a hammer. The O-ring on it looked dinged up (maybe it was leaking and that was excuse to over tighten) so I replaced it.
Diagnostic computer codes 301 and 507 prioris S-Series Tech 1 12-20-2012 03:40 PM
OBD2 diagnostic codes....? captaintrips S-Series Tech 13 12-08-2012 05:48 PM
Diagnostic codes?? jdb30 S-Series General 4 09-27-2012 03:21 AM
Diagnostic Codes Kessler Vue Tech 3 02-22-2012 06:44 PM
Can someone help w/ my 92 saturn sl 1 and diagnostic codes?! 92teal_saturn S-Series Tech 6 09-09-2010 01:16 PM
