#1 |
![]() Join Date: Aug 2003
2002 VUE 3.0L
I'm getting codes for both banks being lean. The car seems to be running fine. Maybe it's not accelerating as hard as normal, I can't really tell. Not long ago, the ECM, throttle body, and rear cat were replaced. It had issues with no throttle response sometimes and then ran terrible when the cat went bad. It ran great after these repairs and still does.
When these new codes occurred, I suspected the rubber/cork gasket that I used on the throttle body. I knew it wasn't the correct material, but it was all I could find at the time, 100 miles from home. I replaced the gasket with one made from the correct rubber material (according to the guy at O'Reillys) a week ago and cleared the codes. It ran great and didn't show any codes, until today. Now I'm getting the same lean codes again. Ideas? 2002 VUE AWD 3.0 V6, 113k miles. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
![]() Quote:
Here a few thoughts from FSM re 0171 and 0174: o A skewed mass air flow (MAF) sensor may set this DTC. o The system will go lean if an injector is not suppling enough fuel. o A skewed engine coolant temperature (ECT) may set this DTC. o The system will go lean during high fuel demand.
I visit forum monthly, if at all. Feel free to send private messages if you think I can help. Don't use visitor message as I never check those. |
#3 | |
2002 VUE 3.0L
![]() Quote:
#4 | |
![]() Quote:
Diminished flow would affect both banks. My comment about checking sensors for residue was way weak - I should have included a note from FSM regarding anti-seize compound - if used: Notice: Silicone based products will contaminate the HO2S. Use only a nickel based anti-seize compound that does not contain silicone. If you didn't use silicone based lubricate during removal of old HO2S, or silicone based anti-seize when installing new one, I'd cross off the list.
#5 |
Do you feel anything different in the way the transmission shifts? If it feels like it is slipping and then grabbing you might want to give your MAF a real good cleaning or replacement.
ernesto
2000 LS2 (Sold, Sigh) 2003 VUE 3.0 FWD 2002 MINI Cooper R50 1978 GMC PU 7.4L 2020 Subaru Impreza |
#6 |
And to add my 2-cents here, is there a possibility of a vacuum leak between the maf sensor and main intake manifold? This would cover the flexible coupler for the maf sensor between it and the throttle actuator and the throttle gasket. Any loose coupling here would allow a vacuum/lean mixture as well as the throttle actuator gasket left loose for the same vacuum leak.
VCX NANO |
#7 |
2002 VUE 3.0L
#8 | |
2002 VUE 3.0L
![]() Quote:
#9 |
Was your thermostat changed ?what do you mean by intake cover plate, the plastic piece on top of the engine? or the aluminum intake, if its the plastic cover take the cover off and check and re-torque the intake bolts to spec.I believe there are six torx bolts.
#10 | |
2002 VUE 3.0L
![]() Quote:
No SES light, but the noise is still there at high rpm. I can't tell if it's a vacuum leak, an exhaust leak, or something vibrating. It kinda reminds of the noise my belt tensioner made when the bearing went bad, but it doesn't make the noise if I rev it in neutral. Maybe I'll crawl under it tomorrow and have a look at the exhaust system. |
#11 |
texan ... the lean codes would probably appear if you had a significant vacuum leak.
According to 3.0 documentation - the intake manifold has vacuum controlled switchover valves in each intake runner to improve performance. GM released at least one service info document pertaining to possible flapper valve noises. It primarily addresses a "clunk" noise but is it possible as the vacuum motors age the valves might make other noises? I don't have the 3.0 but have attached the bulletin in case you've not seen.
#12 | |
2002 VUE 3.0L
![]() Quote:
Bookmarks |
03 Vue-Running 'lean'-OBD II P0171 & P0174 | KSVUE | Vue General | 15 | 08-28-2011 11:46 AM |
P0171 P0174 codes on 3.0 Vue | IMkenNY | Vue Tech | 4 | 04-03-2009 06:05 AM |
P0507, P0171, P0174 (3.0 V-6 L81) | wfransee | Vue Tech | 1 | 12-20-2007 06:57 PM |
Need advice - P0171 & P0174 | Hakman | L-Series Tech | 8 | 07-05-2007 03:01 AM |
Service Engine Soon P0171 & P0174 HELP? | programmer12 | L-Series Tech | 11 | 09-01-2004 12:39 AM |
