Old 04-26-2021, 08:19 PM   #1
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
2000 SL1
Default Dome Light Fix!
Ok, so I'm sure everyone has their own fix for the utterly terrible dome lights, so I thought I'd throw my own idea in. It's not perfect, but it works.
And quick note, ignore the headliner, it was a smoker's car and I've been tearing at the fabric as it comes down. I bought some new liner and I'm just waiting for the weather to get warmer so I can put it in
SO. I took a neodynium magnet and a washer with some double-sided 3M automotive tape and made this fix. It's ghetto, but it works. The best part is you can still remove the dome light if you need to! I did note that the side with the magnet doesn't quite sit as flush as it used to, but at this point I don't really care. I mean, you probably wouldn't be able to tell unless you were looking for it.
I would not suggest doing this if you are running a normal incandescent bulb as it would most likely heat up the tape and melt it. I'm using an LED upgrade light:
https://www.ebay.com/itm/32288714597...53.m2749.l2649
I'm using the LASFIT because they're a really good, high quality brand that has decent prices and they're one of the few higher end brands that puts heat sinks on their bulbs to help keep them from burning out (ask me how I know about this issue). I upgraded my Silverado to all LED from LASFIT and they work awesome!
The only downside to using this particular bulb is that it doesn't have the looped wire, but it still fits in the slots nice and tight and it's hella bright. Also, you could actually turn the bulb if you wanted more light shining up front or to the back since it's facing one direction.
cujoe_da_man is offline   Reply With Quote
Old 04-26-2021, 11:51 PM   #2
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Default Re: Dome Light Fix!
Looks like it came out pretty good. Magnets seem like a great way to hold/repair something like that
97 SL2, auto, 123K miles
Old 04-27-2021, 09:04 AM   #3
Very clever fix!
Old 04-28-2021, 04:43 PM   #4
I hate you. A year or two ago, I tried led dome light replacement from AutoZone and it was dimmer than the factory lamp. Returned it. I bought a penlight led wth similar leds aligned along the little light like the led dome light. Very bright and clipped to my visor. Apparently the aftermarket leds for upgrading lighting have improved.
Old 04-28-2021, 07:04 PM   #5
cujoe_da_man
2000 SL1
Yeah, the LASFIT bulbs are almost TOO bright, but I don't mind at all, it really helps at night if you drop something in your vehicle
Old 04-28-2021, 10:57 PM   #6
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
I put this bulb in my dome light...
https://www.superbrightleds.com/more...-44mm-car/244/
NGK BKR6E-11 spark plugs
Old 04-29-2021, 01:55 AM   #7
Zeebins
Zeebins's Avatar
I've tried a few led bulbs for the map/dome light now and ended up settling on the bulb mattwithcats linked. (90% of my bulbs are Superbright LEDs at this point lol)
I will say though that for whatever reason, the Superbright 561 bulb is hardly any brighter than an basic incandescent when used in the dome lamp. I know it's a bright bulb from testing it with a 9volt, and being blinded by them when used in the map lamps. This bulb just doesn't work very well with this particular dome lamp reflector it seems. Getting a different LEDs from amazon is probably a better option if you don't have map lamps so stick 2 more Superbright LEDs in. I've tried a few cheap ones and they've all been brighter, but also more blue. Otherwise you might as well stick with an incandescent unless all you want is the cleaner looking light.
Old 04-29-2021, 04:43 PM   #8
cujoe_da_man
2000 SL1
At the risk of sounding ghetto, you could probably put a slice of tin foil behind the LED to direct the light down more. Not like anyone would see it and the LED doesn't get nearly as hot as an incandescent bulb.
Old 08-31-2021, 09:22 PM   #9
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
Many years ago I put three of those LED bulbs in my dome light by using 24 gauge wire and soldering the 2 extra bulbs on either side of the center bulb that is clipped onto the loop connectors. Itís plenty bright. I later wired an LED bulb in each footwell, itís easy to see if you dropped something on the floor even at night!
It's GOOD to have a spare!
termite is offline   Reply With Quote
Old 09-01-2021, 02:17 PM   #10
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
1999 SW2
If anyone needs the magnet for these, the L-series dome light uses a neodymium magnet with a spacer that can be removed and glued to the S-series dome light. It is a perfect fit with the headliner.
'97 Saturn SL2 @ 146k (M. swapped) - In storage, awaiting an engine rebuild
'99 Saturn SW2 @ 92k (M. swapped) - Daily Driver
r/Saturn_Cars moderator
dome light help... saturn79 S-Series Tech 6 05-26-2014 03:39 PM
Dome light and Map light problems jsfocke Vue General 9 12-12-2013 04:32 PM
Dome Light AQuinn19 S-Series Tech 7 08-11-2012 07:07 AM
Weird one: passenger door fails to light dome light. tehSaturn S-Series Tech 7 09-09-2011 04:14 PM
Dome Light karinhesed86 S-Series General 9 04-24-2007 07:57 AM
