Old 06-20-2021, 08:54 PM   #1
kg6mvb
kg6mvb has a spectacular aura aboutkg6mvb has a spectacular aura about
kg6mvb's Avatar
2003 ION-1 Sedan
Default TIV transmission fluid left blue stain
I changed the transmission fluid in my 2003 Ion sedan today. A little bit of the special T-IV fluid spilled on the concrete (new, not what I drained). I cleaned it up with kitty litter and it seemed fine. Now, hours later there is a blue stain where the spill was. It was red this morning when spilled.
What would make the stain turn blue?
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
kg6mvb is offline   Reply With Quote
Old 06-27-2021, 12:29 PM   #2
Citation84
Citation84 has a spectacular aura aboutCitation84 has a spectacular aura about
Citation84's Avatar
2005 ION-1 Sedan
Default Re: TIV transmission fluid left blue stain
Could be any sort of fluid reaction with minerals in the concrete.
Dexron turns black on mine [ 86 OLds Calais with GM Hydra fluid]. I would expect my 05 ION with GM Hydra to do the same
Citation84 is offline   Reply With Quote
Old 08-22-2021, 06:36 PM   #3
rjc862003
rjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the rough
Pretty sure its intentional for leak detection
red/brown is easy to miss on the ground, blue stands out
removing the stain is going to suck as its permeated the concrete
rjc862003 is offline   Reply With Quote
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 07:55 PM
Does left axle removal require fluid drain? RobertGary1 S-Series Tech 10 03-02-2013 02:53 PM
Blue vs Pink Washer Fluid JeffTheJoc General Saturn Discussion 6 02-08-2013 05:37 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 06:57 AM
BLUE left fender 4 a 2001 SC2 docholliday S-Series General 2 10-03-2008 12:40 PM
