Old 05-05-2021, 12:50 PM   #1
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
Default Rewiring DRL's to something else?
Just curious, I understand that the DRL's are wired for the high beams, but are they on a separate circuit from the actual headlight circuit? I've always disliked the DRL's on any car being the headlights and was curious if the DRL's could be routed to something else, maybe some really bright LED lights or the fog lamps or something like that.
More of a "what if", not something I NEED to do
Check out my current SL1!
http://www.saturnfans.com/forums/showthread.php?t=268456
cujoe_da_man is offline   Reply With Quote
Old 05-05-2021, 03:39 PM   #2
Default Re: Rewiring DRL's to something else?
If you're comfortable with wiring diagrams, S-series DRLs use a complicated configuration. S-series wired high beams for DRLs. Regular parallel wiring for full power high beams. A relay and extra wiring dedicated to drl lighting. Posted in past threads.
If you're not comfortable with complicated drl wiring but want to disable it, a simple mod to the drl relay kills it but leaves high beams for regular use.
It's probably not a good idea to rewire the drl circuit for other use.
Old 05-05-2021, 03:43 PM   #3
cujoe_da_man
I kinda had the same feeling it might mess something up, but wanted to ask first before I even looked at it. Like I said, more of a curiosity than anything.
Old 05-06-2021, 10:07 AM   #4
Seems simple enough to rewire the DRL's for something else...pull the relay out, fold the offending pin over and use that pin to switch your add-on relay.
Old 05-06-2021, 12:26 PM   #5
cujoe_da_man
I might just pull the relay altogether. When it's cloudy out, I like to have my running lights on and it looks weird with the DRL's because it looks like I'm driving with my brights on. I know, I'm weird that way.
Old 05-06-2021, 11:49 PM   #6
The fun part of the S-Series DRL system is if you pull the DRL relay you lose the right side high beam if not the entire right side headlight.
Old 05-10-2021, 08:09 PM   #7
cujoe_da_man
Yep, finally got a chance to test it myself, no high beam without the relay. Oh well, not a big deal anyway, guess I'll live with 'em.
Old 05-10-2021, 11:39 PM   #8
mbr
mbr will become famous soon enough
1998 SW2
When you pull the relay, you have to use a small wire to jump two terminals. I forget which ones, but a search will find it.
Maybe in the morning I'll take a pic of mine and post it.
Accuracy MATTERS!
mbr is offline   Reply With Quote
Old 05-11-2021, 09:59 AM   #9
mbr
1998 SW2
Here's a pic of the relay removed and the terminals to jump. This will kill the daytime running lights and preserve all the headlights on both sides.
I also highly recommend the GM quad headlight mod. This will keep the low beams on when the high beams are on. Big help on dark roads. It involves a 30 amp relay and some wiring. A search will find a color coded diagram that applies to GM cars with four headlights.
Accuracy MATTERS!
Old 05-11-2021, 10:14 AM   #10
cujoe_da_man
I thought about doing that, but I wasn't sure which slots to jump, I'll look into doing that.
I was also looking into the quad beam setup too. I did it on my Silverado, but all I had to do with that was re-ground the ground wire so it would keep the low beams on with the high beams.
Old 05-11-2021, 10:25 AM   #11
DRLs are about a couple hundred lumens dimmer than the low beams.
One of the "sounds good, never got around to it" things I considered was jumpering the relay to a switch, to disable/enable DRLs from the driver seat
http://www.saturnfans.com/forums/sho...pass+DRL+relay
But considering how many people pull out in front of me or do other stupid s**t when I have headlights on, I decided to keep the DRLs, as I need all the visibility I can get.
I also considered that because I drive some pretty dark roads, or used to before pandemic.
http://www.saturnfans.com/forums/showthread.php?t=9617
But since I ended up with a coupe that has the cutoffs, I modified a high beam bulb to fit into the the passenger low beam socket and have it aimed low. Light up that side really well, don't get people flashing me, either so hopefully it is not blinding.
Clipped OBDII, Need help for rewiring Border Walker S-Series General 3 07-29-2014 06:10 PM
Brake Rewiring... 4littlemonkeys Relay General 7 09-05-2007 07:53 AM
Rewiring Fan agoldslsaturn S-Series Tech 13 05-06-2006 11:59 PM
Rewiring Infinity Basslink in the Vue VueGeoff Vue General 3 08-06-2005 03:04 AM
