Old 06-27-2017, 11:13 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question 2004 Saturn VUE compressor works but no cold air
Hello again...
2004 Saturn VUE AWD 178k
compressor work but no cold air...both fans work the moment I press AC button
Guage that came with refrigerant shows its in green zone related to ambient temp
When I turn the knob to heat ...it does blow hot air
but in cold position with AC on ..just normal ambient air..not cold air..
Please suggest where would be the problem?
I am guessing air/moisture in the system rather than refrigerant? so even though gauge shows normal level it might be just air and not refrigerant?
If this is the cause...how do I empty that air ..without getting exposed to refrigerant ?
Also I see only low service port ....I dont see high service port....so in this car only one port?
vikasevan is offline   Reply With Quote
Old 06-28-2017, 12:14 AM   #2
billysvue
Default Re: 2004 Saturn VUE compressor works but no cold air
TAke it to a shop to pull a vacuum on the system , wait awhile to see if it holds vacuum( leak check), then recharge it and set the pressures.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 06-28-2017, 02:04 AM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
So there is no high port in these cars?
Only low port ? if so how one can use manifold gauge set?
Old 06-28-2017, 10:14 AM   #4
billysvue
By following a service manual, or digging into this forum's search feature.
'17 Suby Forester
Old 06-29-2017, 01:42 PM   #5
atikovi
Don't recall off the top of my head which is which but one is on the right side on the hard line,
and the other on the left in front of the strut tower,
but just from the wording of your post, "If this is the cause...how do I empty that air ..without getting exposed to refrigerant ?" seems you are over your head.
Old 06-30-2017, 07:56 PM   #6
Mustangman03
Mustangman03 has a spectacular aura aboutMustangman03 has a spectacular aura aboutMustangman03 has a spectacular aura about
2002 VUE 3.0L
I'm guessing he gave up?
Mustangman03 is offline   Reply With Quote
Old 06-30-2017, 11:38 PM   #7
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
I have ordered manifold gauge and vacuum pump ...
atikovi what do u mean ...I am over my head?
Old 07-01-2017, 07:20 AM   #8
atikovi
When you say, how do I empty that air ..without getting exposed to refrigerant, it sounds like you don't understand how a sealed refrigeration system works. You don't "empty the air," you vacuum out the entire charge of freon and replace it.
Old 07-01-2017, 07:28 AM   #9
Mustangman03
2002 VUE 3.0L
Oh lol have checked the operation of the blend door?
Old 07-01-2017, 01:22 PM   #10
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Yes that was my question.
When I vacuum out Freon..it will be released in environment correct? So I and others will be exposed to that freon?
Since I don't have recovery tank..there is no easy to collect this Freon.
Old 07-01-2017, 02:03 PM   #11
Mustangman03
2002 VUE 3.0L
You need to take it to a shop and have them vacume it down and check for a leak.. then they will inject dye and charge it and check the system operation.. I have to do the same so I can change my expansion valve.. mine only blows at 68 degrees..
Old 07-20-2017, 08:26 PM   #12
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Bought ac manifold kit and pulled vacuum..it did hold vacuum ...for about 15 minutes...I did not have patience to wait any longer...
When I checked low port pressure with this gauge kit ...it shows 45 at low and high at 75 psi...
clutch does engage...
Still no cold air...
Do u think compressor is not working?
2004 Saturn Vue redline fuel pump works intermittently pakimex Vue General 2 04-28-2016 07:26 PM
2004 Saturn Vue 3.5 liter AC Compressor Kit torresgg Vue Tech 1 08-14-2015 08:13 AM
2004 Saturn Vue AC Compressor Replacement 3.5 Davidss Vue Tech 24 11-03-2014 08:10 PM
A/C compressor works only when temp is high cjsnare S-Series Tech 2 05-26-2010 10:43 AM
ION 3 works well in cold weather scion Ion General 1 01-10-2004 02:36 AM
