Old 11-28-2016, 02:55 PM   #1
Kwillis
Kwillis is on a distinguished road
2008 Astra XR
Default Wheel speed sensor
Check engine, abs, and traction control lights all came on ran the codes. Came back as front left wheel speed sensor. I have already found the part for $55 just looking for any advice for changing this out.
Kwillis is offline   Reply With Quote
Old 11-28-2016, 05:53 PM   #2
Default Re: Wheel speed sensor
Post actual error code. The conservative way might be, if the error code points to exact sensor and location, to jack up the front end and examine wiring and sensor for damage from exposure. Compare left to right side for any clues. Some reluctors are exposed and visible as a steel toothed ring around the CV joint whole others are hidden from view. Exposed ones can crack, creating incorrect wheel speed signals, triggering an error code.
Old 05-30-2017, 02:23 AM   #3
MaxwellS
MaxwellS is on a distinguished road
2008 Astra XR
I have the same thing going on; on my 2008 Astra XR manual trans.
"C1221 LH Front Wheel Speed Sensor Input Signal Is Zero"
MaxwellS is offline   Reply With Quote
Tags
wheel speed sensor
abs rear wheel speed sensor troutman11111 Vue General 8 04-23-2015 09:23 AM
Why do I have a wheel speed sensor?? jjroyer Vue General 17 08-12-2012 04:04 PM
wheel speed sensor bigdude2468 2008 Vue 1 03-31-2012 03:00 AM
ABS wheel speed sensor warrenc Ion Tech 18 12-22-2011 12:06 AM
ABS wheel speed sensor failed silvervoo Vue General 3 08-18-2004 01:37 PM
