Old 03-30-2012, 04:38 PM   #1
bigdude2468
bigdude2468 is on a distinguished road
Default wheel speed sensor
Has anyone had issues with wire chafing of the wheel speed sensors? I have a 2008, 3.8 liter AWD and I have had three of the four speed senors repaired due to chafing of the wire. No need to replace, they just repaired the wire, all under warranty. I am going to get underneath the vehicle tomorrow and try to see where the damage occurs and maybe reroute the fourth one to a place where it does not get worn through.
bigdude2468 is offline   Reply With Quote
Old 03-31-2012, 03:00 AM   #2
BluVu
BluVu is on a distinguished road
BluVu's Avatar
2008 VUE 3.5L
Default Re: wheel speed sensor
I had the same thing happen to my LF wheel I believe.. The wire chafes against the control arm, and there really is no better way to route it, the way they have the sensor positioned on the wheel. The dealer repaired mine under warranty and put some kind of heavy plastic sleeve over the wires on both front wheels, which has held up for over 50k miles now.. but you can see where it still chafes against the metal, it's nice and shiny..
I haven't had any problems with the rear wheels, I would assume since they don't turn (side to side). That's a bit odd that one of your rear wheels was chafing the wire as well.
I would recommend putting some kind of heat shrink, or at least electrical tape on yours if the dealer didn't when they repaired it the first time.. then at least when that wears down it's an easy fix.. just add more tape.
Hope this helps
BluVu is offline   Reply With Quote
ABS wheel speed sensor warrenc Ion Tech 18 12-22-2011 12:06 AM
c0040 right wheel speed sensor circuit Vue in Ontario Vue Tech 13 12-09-2011 09:32 AM
ABS Wheel Speed Sensor Replacement... Baron5867 S-Series Tech 4 10-18-2011 11:14 PM
hand wheel speed sensor sierrap615 S-Series Tech 3 05-21-2005 12:37 AM
ABS wheel speed sensor failed silvervoo Vue General 3 08-18-2004 01:37 PM
