Old 10-19-2011, 02:25 PM   #1
suikenny
suikenny is on a distinguished road
Default Electrical Issues
My '98 Saturn SC2 has two main electrical problems. First, the dashboard lights either do not work or shut off when I turn on the headlights. Second, the battery does not turn off when I turn off the car. I have to manually disconnect the battery every time. Any ideas?
suikenny is offline   Reply With Quote
Old 10-19-2011, 02:33 PM   #2
Default Re: Electrical Issues
Which dashboard lights? The illumination lights or one or more of the indicators?
Do the parking lights work?
The battery never turns off; it doesn't have a switch. What, in particular, stays on when it shouldn't, when you turn the key back to OFF?
Old 10-19-2011, 02:45 PM   #3
suikenny
The illumination ones. The parking lights work. And the dashboard lights did stay on (maxed out brightness no matter where i had the dial at, this was before they went out), I can still use the windshield wipers, and I can turn off my stereo manually, but it also doesnt turn off.
Old 10-19-2011, 03:41 PM   #4
When did they go out? It's sounding like the dimmer has failed.
The radio and (if I'm remembering correctly) wipers will work with the key in the ACC position. Are you sure you're turning the key all the way back to OFF (two clicks back from RUN) before removing the key? Sometimes, when either the key or the cylinder is extremely worn, it's possible to take the key out with the cylinder in ACC or RUN.
Electrical issues antonio765 L-Series Tech 1 11-29-2009 09:36 AM
Electrical Issues...Please Help rlynge S-Series Tech 1 10-31-2009 05:48 PM
03 vue electrical issues thedean316 Vue Tech 0 10-22-2006 08:20 PM
electrical issues diestrutionomeg S-Series General 0 04-08-2005 04:26 PM
Electrical issues SLVR_Saturn S-Series General 5 01-20-2004 07:25 PM
