Old 07-21-2010, 01:04 AM   #1
dbswayne
dbswayne is on a distinguished road
Default 2001 L-series groan on left turn, speed dependent
My 2001 LW200 with 115K has runs great - except now it's starting to emit a front end groan when I make quick left turns (e.g., across rapidly approaching oncoming traffic). I read another thread or two that described similar symptoms, but none that talked about it being speed dependent, or specifically associated with left turns only. They suspected a rack or power steering problem - but I was hoping to hear someone comment who has experienced just these symptoms.
BTW - PS fluid level is fine.
Dave
dbswayne is offline   Reply With Quote
Old 07-24-2010, 10:32 AM   #2
HV Fam Wagon
HV Fam Wagon is on a distinguished road
2000 L-Series 3.0L Wagon
2004 L-Series 3.0L Wagon
Default Re: 2001 L-series groan on left turn, speed dependent
It could also be wheel bearing. It happened to my LW2 three years when she has 90K miles.
HV Fam Wagon is offline   Reply With Quote
Old 08-08-2010, 09:58 PM   #3
TVCCS
TVCCS is on a distinguished road
TVCCS's Avatar
2008 AURA XR
FYI...there was a TSB on this a few years ago...the rack design was changed mid-2003 to get rid of it, but it's not a cheap fix, obviously. If I get on my system that has that Bulletin saved on it...I'll post it.
TVCCS is offline   Reply With Quote
Old 08-11-2010, 07:42 AM   #4
TVCCS
TVCCS's Avatar
2008 AURA XR
If it's just to the left, Saturn had a TSB on this awhile back up to a certain VIN in 2003. Bulletin below:
Whistle Noise from Power Steering While Turning Left #02-T-77 - (Apr 24, 2003)
Whistle Noise from Power Steering While Turning Left (Replace Power Steering Gear)
2000-2003 Saturn L-Series - Built Prior to VIN Breakpoint 3Y521530
Condition
Some customers may comment on a whistle noise while making slight left turns.
Cause
Condition may be due to the power steering gear.
Correction
Refer to the "Power Steering Gear Removal and Installation Procedure" found in the Steering Section of the appropriate Saturn L-Series Chassis Service Manual. Replace the Steering Gear with P/N 22708505 which has internal modifications to correct the whistle noise concern.
Procedure
1. Verify the customer concern of whistle noise.
Important
The changes in Steering Gear P/N 22708505 are only for the whistle noise.
2. If the whistle noise can be heard with slight left steering input, refer to the "Power Steering Gear Removal and Installation Procedure" found in the Steering Section of the appropriate Saturn L-Series Chassis Service Manual. Replace the Steering Gear with P/N 22708505.
Parts Requirements
Part Number
Description
22708505
Steering Gear
Left turn signal not working 92SC2 S-Series Tech 22 04-12-2009 10:45 AM
groaning while making left turn STRNGUY Aura General 6 12-03-2007 04:36 PM
Engine dies with Left turn Green92SL2 S-Series Tech 8 07-24-2007 11:53 PM
Strange noise on first left or right turn after starting donedds S-Series General 3 02-19-2006 02:59 AM
rythmic metalic squealing on left-hand turns on accel; tire noise on normal left turn rtfm17 S-Series Tech 4 08-25-2003 09:37 AM
