Old 08-06-2008, 07:04 AM   #1
Grimx1
Grimx1 is on a distinguished road
Question 2004 4Cyl No radio audio but CD works
Hi all! New fourm menber and I a weird problem: Yesterday I listened to the radio on the way to work and shut down normally after ariving. When I left for an appointment a few hours latter I noticed the radio was no longer outputting any audio. All the AM/FM preselects still display/select but still no audio. I tried the CD player (6-CD Changer) and all five disks I have loaded play just fine. Any ideas?
2004 Vue, 4-Cyl 88K miles
Grimx1 is offline   Reply With Quote
Old 08-06-2008, 01:08 PM   #2
FGCA_XRL
FGCA_XRL will become famous soon enough
2004 VUE Red Line
Default Re: 2004 4Cyl No radio audio but CD works
Either the tuner is dead or there's something wrong with the antenna. Does it seek to stations correctly? If so you have a dead tuner, and need a new radio.
FGCA_XRL is offline   Reply With Quote
Old 08-06-2008, 01:30 PM   #3
Tasseldad
Tasseldad is on a distinguished road
Happy Re: 2004 4Cyl No radio audio but CD works
Try removing all disks and then turning the vehicle off and on. If the unit doesn't revert to radio when no disks are present it has fried its little brain and needs to be replaced.
Tasseldad is offline   Reply With Quote
Old 08-06-2008, 04:50 PM   #4
Grimx1
Thanks for the reply! The radio appears to seek to stations as well as to all my presets. I'll check the antenna. Thanks again for your help!
GrimX1
Old 08-06-2008, 04:52 PM   #5
Grimx1
Thanks for the reply. I'll try your suggestion about the disks as well as check my antenna. Thanks for your help!
GrimX1
Old 08-06-2008, 09:46 PM   #6
hoob
hoob is on a distinguished road
Does your radio have the ST light? This should help you determine if antenna is working or not. With a good signal the ST should stay on.
hoob is offline   Reply With Quote
Old 08-07-2008, 12:22 AM   #7
FGCA_XRL
2004 VUE Red Line
If it's seeking that means your tuner isn't sending audio to the internal amp. Time to start looking for a replacement.
You can get the 6CD units on ebay pretty cheap, or crutchfield has some good deals on aftermarket stuff. If you're going to go to a big box store, go to a Tweeter/Sound Advice or Circuit City. Avoid Best Buy, and let them wallow in their slow decline to failure.
I'll see you in Hell Best Buy. Don't ever &*$# with your young employees that are going to school. They're your future (not) customers.
2004 4cyl. tire size jimpennjr Vue Tech 3 01-09-2010 09:57 PM
Best Tires for Vue 2004 4cyl SL2Ghost42 Vue Tech 1 01-07-2010 07:32 AM
2004 Vue 4cyl AC Cycling ryanB3 Vue General 8 10-21-2008 06:55 PM
2004 Vue 4cyl. survey billw5012 Vue General 17 09-27-2007 11:06 AM
2004 4cyl 5sp inquiry billw5012 Vue General 6 10-26-2005 10:04 AM
