Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 12-03-2007, 10:26 AM   #1
brutedawg20
brutedawg20 is on a distinguished road
2007 VUE Green Line
Default 2007 Greenline possible service issues
I drove my girlfriends 2007 Greenline Vue over the weekend and she was demonstrating a possible issue with the HVAC vents. When switching from say the floor to the dash vents it takes up to 30 or 40 seconds? Is this normal shes never noticed it before but used the dash vents mostly with the A/C. She likes to switch between the two with the heat. Are these electric, mechanical or pressure activated?
Also now that it is cold outside (Michigan) shes said the car is very loud when its heating up, Why is this? and why on earth would they not put a temperature gauge on the vehicle?
I also noticed a clunk coming from the front end i think passenger side when hitting bumps, I asked her about that and she said that just started also. Any known issues with this?
Thanks for any input.
brutedawg20 is offline   Reply With Quote
Old 12-03-2007, 01:12 PM   #2
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Default Re: 2007 Greenline possible service issues
The HVAC shouldn't take that long to switch between modes, which I think operates with engine vacuum. There may be a problem with the HVAC control system or reduced engine vacuum (although that would probably illuminate the check engine light).
Our GL is a bit louder upon startup in the cold weather than when it is fully warmed up, but I don't think that's exclusive to the GL. It's probably normal, but perhaps they can check the exhaust system for leaks.
There is no temperature gauge because the charge/assist meter takes its place on the panel. Not to worry--there's an engine temp idiot light if there is a problem.
As for the clunk, many VUEs are known for suspension noise, especially in cold weather. Have the dealer (it's still under warranty, right?) check the usual suspects like strut mounts, struts, and sway bar end links.
tackepj is offline   Reply With Quote
Old 12-03-2007, 02:03 PM   #3
brutedawg20
2007 VUE Green Line
Thank you, I'll have her make an appointment to take it in, yes it's still under warranty.
2007 Vue Greenline Drive Belt mcentyre Vue Green Line 15 11-28-2011 04:54 PM
2007 Vue GreenLine mileage, etc. ski4ever Vue Green Line 4 03-15-2010 04:16 PM
electrical issues with my 2007 Outlook smoke1439 General Saturn Discussion 1 10-04-2009 10:32 AM
2007 Automatic Door Issues Mr. Sky Relay General 8 06-04-2007 03:47 PM
2007 Saturn Aura Greenline- Lowest cost hybrid WopOnTour Aura General 25 03-27-2007 07:54 AM
