Old 07-08-2007, 11:43 AM   #1
92SL1Mann
92SL1Mann is on a distinguished road
1992 SL1
Default Adding Aftermarket Temp Guage
Just wondering if anyone has added an aftermarket temp guage (i m sure lots have) but is there a good place to either locate the sensor or is it possible to tap into the sensor that is running the stock guage? 92 SL1 thanks
1992 SL1, 376,000Kms
1996 SC2, 243,000Kms
92SL1Mann is offline   Reply With Quote
Old 07-09-2007, 12:25 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Adding Aftermarket Temp Guage
I haven't done this but, others have. Three options I know of:
  • Put a tee in a heater hose.
  • Locate where the cooling system connects to the manifold and put a tee there.
  • This one's not for the faint of heart but, it would probably yield the most accurate results. Drill a hole in the head above the ECTS and tap it.
Old 07-09-2007, 12:43 PM   #3
DonP
On a '92 with a bit of skill and cunning you could probably use the existing temp gauge sensor.
Old 07-09-2007, 10:18 PM   #4
seahawk
seahawk is on a distinguished road
1997 SC1
That's pretty vague and not much help.^ I like the drill and tap idea because its only aluminum and should be easy.
seahawk is offline   Reply With Quote
Old 07-10-2007, 06:26 AM   #5
BarnOwl
BarnOwl's Avatar
I need to correct myself because I'm not so sure it can be done on a '92. When I answered the question I was thinking about people that put a '96 or later engine in a '95 or earlier car. Then you have a gauge sensor that has to be added. So, it's basically the same problem and one solution is to put a hole where the sensor normally goes in the newer engine. However, in a '92 the second sensor is already there and I'm not certain there's room.
Temp Guage Not working ZacMan-Sc1 S-Series Tech 27 10-07-2009 09:46 PM
06 2.4L, temp guage at zero briansnoopy Ion Tech 7 04-19-2006 09:49 PM
Outside Temp Guage 94SL2ndOwner S-Series General 0 05-06-2005 02:02 PM
HELP!! Glow face guage install! Temp guage error! SpeedySL1 Suggestion Box 2 04-01-2004 04:05 PM
Temp guage acting up dre S-Series Tech 18 07-29-2003 06:05 PM
