Old 08-07-2014, 08:51 PM   #1
Texas_North
Texas_North is on a distinguished road
Default 2002 SL2 Electrical Issues
I've used this forum as a reference for maintenance on my car before and it's always been an invaluable tool. I'm hoping you all could help me with my latest issue:
My 120kish 2002 SL2 with a 5 speed and no ABS is having electrical issues. When I started the car today, the power locks began to have a fit- first the passenger rear door, then the driver's door, then all of them. It was enough to toggle the lock at times, but was a constant switching back and forth. I tried pulling the fuse marked "windows", but this wasn't any help- I think they're on the ECU circuit anyways? I ended up disconnecting the battery and caught a ride to work.
The car is otherwise fine. I did some work to the audio system the better part of 2 years ago. I just replaced the head and speakers with aftermarket units; no subwoofers or anything crazy. It's been fine so far, but I figure any bit of information helps.
I have no idea where to start to diagnose this. I'm mechanically inclined enough to follow a Richpin video, but that's about it. I have some money to replace parts, but don't want to start throwing parts at it because I'm a student and don't have much in the way of extra cash.
I thank you in advance. It may be a few hours before I'm back to give extra info as I'm at work.
Texas_North is offline   Reply With Quote
Old 08-07-2014, 10:06 PM   #2
Default Re: 2002 SL2 Electrical Issues
You have a dirty or stuck switch. You have to remove and clean. The big search box in the center of the page will bring up posts with pictures etc. I detest power doors and windows.
Old 08-07-2014, 10:13 PM   #3
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
I agree, Only more to break....
CHECK YOUR OIL!
Old 08-08-2014, 01:06 AM   #4
Texas_North
[QUOTE=OldNuc;2084836]You have a dirty or stuck switch. You have to remove and clean. The big search box in the center of the page will bring up posts with pictures etc.
Thanks! Just went and did this, seems like the return springs in the switch finally bit the dust. Ended up pulling the entire switch and button assembly like a rotten tooth, problem's gone. Now to decide if I want to replace it.
Old 08-08-2014, 08:22 AM   #5
Find a good one at the pick and pull, take it apart and carefully clean it up. With a little maintenance they last a long time.
Old 08-08-2014, 01:29 PM   #6
Texas_North
Will do. Since it's non essential and my power locks still work, I figure I'll just leave it as is until I end up at the salvage yard for whatever other component I need. Thanks again for all your help, it's very much appreciated
Old 08-08-2014, 04:06 PM   #7
Don't wait too long to go shopping as all of those parts are going fast.
ecu, electrical, gremlins, locks, power
Electrical Issues saturn03 Ion General 5 01-20-2014 09:44 PM
2002 L300 V6 Pedal Position Sensor/Electrical issues? PleasantOne L-Series Tech 18 09-09-2013 09:57 PM
Electrical Issues suikenny S-Series Tech 3 10-19-2011 03:41 PM
electrical issues.. i think mattachuz L-Series Tech 8 12-02-2010 09:59 PM
Electrical issues DarkNexxus S-Series Tech 9 01-20-2009 11:26 PM
