Old 02-21-2021, 02:50 PM   #1
jeopardy98
jeopardy98 has a spectacular aura aboutjeopardy98 has a spectacular aura aboutjeopardy98 has a spectacular aura about
Default 04 Saturn Vue MT speed dependent hum- wheel bearing done
Hey All, well those that are left. My faithful Vue had a bad wheel bearing so I replaced it. I actually replaced 3 of the 4 this far but the hum didn't go away. I have added tranny fluid and I still get a hum. It is almost like it is coming from the CV joint but there is no clicking at full lock. The sound also gets louder when weighting the passenger side and quieter when weighting the driver side. It isn't significantly different but noticeable. The noise gets louder with speed and there is no change in gear or in neutral with the clutch depressed or engaged.
I'm racking my brain and cannot figure out what is causing the noise. Any ideas at all? Thank you in advance!
'07 ION 2
'05 Malibu Maxx
1987 Dodge Dakota
1996 Jetta GLS
'04 Suzuki SV650
1985 Honda ATC250SX
jeopardy98 is offline   Reply With Quote
Old 02-21-2021, 11:39 PM   #2
bluesl2
bluesl2's Avatar
Default Re: 04 Saturn Vue MT speed dependent hum- wheel bearing done
It's most likely the one wheel bearing you have not replaced. The fact you said the noise changes when loaded then unloaded speaks volumes as to it being a wheel bearing. You have probably noticed, Vue's eat wheel bearings.
Old 02-23-2021, 04:13 PM   #3
jeopardy98
I would have thought so too but that is the rear driver and this noise is 100 percent coming from the front left wheel. That wheel bearing has been replaced twice already. The 1st one failed after 500 or so miles and I replaced it under warranty. The one I installed on Saturday felt great but as soon as I took my test drive the noise is still there. Every part of me says it is another wheel bearing but the odds of getting another bad one are pretty low.
What am I missing? What else could make that noise? Why would it be faulty immediately after install? I am banging my head against the wall here. I appreciate any suggestions.
'07 ION 2
'05 Malibu Maxx
1987 Dodge Dakota
1996 Jetta GLS
'04 Suzuki SV650
1985 Honda ATC250SX
Old 03-02-2021, 02:10 PM   #4
jeopardy98
Hey all, I'm still battling this. I noticed on a recent interstate trip that at 72 the noise begins to quiet and at 75 it is completely gone. At 76 it begins again louder than it is at 40-65. Any ideas at all as to anything else I can or should check?
'07 ION 2
'05 Malibu Maxx
1987 Dodge Dakota
1996 Jetta GLS
'04 Suzuki SV650
1985 Honda ATC250SX
Old 03-02-2021, 06:54 PM   #5
waiter21
2003 VUE 2.2L
Did you also replace the idler bearing on the passenger side CV joint?
Old 03-11-2021, 11:21 AM   #6
jeopardy98
Do you mean the jackshaft bearing? If so then yes, that has been replaced within the last 6 months. If I am not mistaken that sounded like more of a clunk when I was having an issue with that one. Or are you referring to a different part?
'07 ION 2
'05 Malibu Maxx
1987 Dodge Dakota
1996 Jetta GLS
'04 Suzuki SV650
1985 Honda ATC250SX
Wheel bearing saturn SL Arcast S-Series Tech 1 05-29-2014 01:13 PM
2000 Saturn SL1 On 5th Wheel Bearing mattsh S-Series Tech 20 01-20-2014 01:45 PM
Saturn ion wheel bearing problem Shynes Ion Tech 1 10-31-2013 05:31 AM
2001 L-series groan on left turn, speed dependent dbswayne L-Series General 3 08-11-2010 07:42 AM
Wheel Bearing Question - Not Saturn blackeagle1 S-Series Tech 8 02-01-2007 01:34 AM
