Old 04-09-2007, 09:10 AM   #1
aperseghin
aperseghin is on a distinguished road
aperseghin's Avatar
Default Home Depot
Well i was working on a SIMPLE intake, basically just adding a high flow air filter and removing the intake filter box. Well the part i purchased from the speed shop to connect the stock intake to the filter (it was a 60% bend) would not fit properly, it kept falling off. Well i went to home depot and purchased a universal dryer vent elbow as seen on the end of this tube http://www.applianceblog.com/archives/DryerVkit.jpg it spins along those angled ribs you see and adjusts to many angles. Well it worked perfectly in a pinch (since i did not want to put the box BACK on) it actually sounds pretty good too.. ill post a pic soon. its not a permanent solution but damn if it fit perfectly...
~~~~~~~~~~http://www.yourlastrites.com/saturn~~~~~~~~~~~~
1999 SC2 3- Door Coupe.
DIY Custom Short Ram Intake.
69,000 miles
aperseghin is offline   Reply With Quote
Old 04-09-2007, 01:16 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Home Depot
You know you're a Saturn owner when...................................
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 04-09-2007, 01:22 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
hey it's not PVC
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-09-2007, 01:29 PM   #4
Don't forget to clean the lint trap at every gas fill-up....
Old 04-09-2007, 03:58 PM   #5
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
lmao.
1996 SC1
RalliArt16 is offline   Reply With Quote
Old 04-09-2007, 04:40 PM   #6
LowSC2
LowSC2 is on a distinguished road
LowSC2's Avatar
1999 SC1
1991 SL2
Scary.. Just plain scary.
Jeff Silva ~ 91 SL2 - 11.809 @ 116.488mph
•Chilton & Haynes manuals are junk
•Changing the ECTS doesn't fix everything
LowSC2 is offline   Reply With Quote
Old 04-09-2007, 04:54 PM   #7
aperseghin
aperseghin's Avatar
LOL i know its bad.. but it works... im buying some mandrel bens this weekend.. i found a place in my area.. and they match their ebay prices localy so i dont have to pay shipping..
http://www.mandrelbendingsolutions.c...let/StoreFront
69,000 miles
Old 04-09-2007, 10:49 PM   #8
Abeo
Abeo is on a distinguished road
Abeo's Avatar
2006 VUE 2.4L
I think I saw that on the Dolorian from Back to the Future. :-P
JK, nice fix in a pinch. Just don't let it go! Wish I was creative.
Abeo is offline   Reply With Quote
Old 04-09-2007, 11:07 PM   #9
Living_Colour
Living_Colour is on a distinguished road
Last I checked the car in Back to the Future was a DeLorean...
Living_Colour is offline   Reply With Quote
Old 04-10-2007, 04:02 PM   #10
Abeo
Abeo's Avatar
2006 VUE 2.4L
I can't spell to save my life.
Old 04-10-2007, 07:30 PM   #11
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
2002 L-Series 2.2L Sedan
thats a good idea... maybe u can go in and ask for an aluminum pipe, and measure how long it needs to be from end to end to fit in the car... and ask them to put opposing 90deg bends on both ends
that way its all very smooth with no rough edges inside, and no welding required... then just set it in the car to see how it fits and cut the ends as needed so it fits best.
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
xupthree60 is offline   Reply With Quote
Old 04-10-2007, 10:59 PM   #12
eRic 02sc2
eRic 02sc2's Avatar
here's something I found while cleaning my inbox
To: Saturn Performance Club Mailing List
Subject: Re: [SPC-List] Cold Air Intake
> I'd clamp a K&N cone directly to the throttle body before buying some
> crap on eBay. I forget the part number but you can measure the
> throttle body outside diameter and the distance from the throttle
> body to the brake fluid reservoir and look in the K&N catalog to find
> one that fits without hitting anything.
I also forget the part number, but a K&N for a 1980-1983 BMW 320i will clamp
onto the throttle body with no problem. You can see this setup on the
$2004 Challenge SL2 at:
> Of course you'll need to do something with the air temp sensor.
The filter I mentioned is a cylinder with a plastic end cap. I drilled a
small hole in it and stuck the sensor inside. Needed to splice in some
wires to reach to the sensor's new location, but that's easy.
In my previous 96 SL2, I used OBD-II to my advantage to monitor the air temp
of various intake configurations. With a typical Powerstack setup, once the
engine bay heats up, the air doesn't cool off again once you start moving.
But with the "shorty" intake, you *do* get cool air after you're moving. My
theory is that air flows underneath the car and then up between the motor
and the firewall. I removed the rubber weatherstripping at rear of the
engine bay to encourage this behavior.
$30 for a filter vs. $150 for a Powerstack, and it works better, too.
eRic 02sc2
Last edited by eRic 02sc2; 04-10-2007 at 11:08 PM. Reason: removed names to protect the guilty
My HCE is home. PSDFan S-Series General 19 05-11-2009 05:53 PM
DO NOT try this @ home JoeyD Astra General 1 11-23-2008 01:49 AM
Home Sweet Home 1saxman Vue General 1 10-23-2007 11:51 PM
a new home forsale Classifieds 5 05-08-2004 11:52 AM
Spoiler Depot spoiler pics. BlueDevil Vue General 6 03-23-2004 08:12 PM
