Old 09-08-2009, 04:48 PM   #1
heavyd10000
heavyd10000 is on a distinguished road
heavyd10000's Avatar
Dizzy Park Light Fuse blows and blows.
OK I know there are a few threads about this but none help.
The other day at night, i turned on my lights and the park lights came on and then off (blew fuse), and now i replaced the fuse and blows right away.
What i have done is check the wiring beside the light plugs (brake/park, front signal/park, front single bulb marker) and have taken every light out stated above.
I have also taken the the connectors off of the dash, heat/ac controls, and taken out the radio.
And i put my multimeter in place of the fuse and its pulling over 20 amps (10 amp fuse)
Is there any place i should be looking next for a short??
Oh yes there is trailer wiring with a black box from crappy tire.
So i need ideas!!
1996 Saturn SL2 1.9L DOHC 5 spd 184K miles (bought 02/09 - Sold 08/2010).
Bought 92 Olds 88 Royale LS - 3800 V6
heavyd10000 is offline   Reply With Quote
Old 09-08-2009, 05:16 PM   #2
Default Re: Park Light Fuse blows and blows.
FIRST - Disconnect the "black box" and re-test.
NEXT - If it's an aftermarket radio, disconnect it and re-test.
NEXT - Disconnect the dash light dimmer and re-test.
Old 09-08-2009, 05:20 PM   #3
heavyd10000
ok done the first 2
dimmer next.
Old 09-08-2009, 05:40 PM   #4
heavyd10000
OK took dimmer out and now it only draws 1 amp - think its fixed, should i get a new dimmer switch??
Old 09-08-2009, 06:24 PM   #5
PM me a reminder, and I'll check the FSM on testing that dimmer. We might be able to temp'ly bypass it to verify the rest of the circuit is okay. If you've got enough spare fuses, just for S&G, you could try it again once each, with the dimmer turned all the way up, and all the way down.
Old 09-08-2009, 07:21 PM   #6
heavyd10000
Well I got the car back together except the dimmer and rear dash cover (putting leather on it to match the front dash) And all the park lights work now - installed new ones, they were old!
But the dimmer is a PWM (Pulse-width modulator), and have built a few for HHO.
I have a military surplus PWM 5 amp 15 VDC, does the dash lights run more than that??
Old 09-14-2009, 03:05 PM   #7
heavyd10000
OK so the interior light dimmer was bad, and replaced with one i had, and works good - pics.
Thanx for the Help.
Fuse Blows motttocs S-Series Tech 9 10-22-2007 05:01 PM
Fuse blows everytime I replace it? solidusjoe S-Series Tech 6 08-30-2007 08:45 AM
No wiper/washer. Fuse blows! peppermrj S-Series Tech 3 05-06-2007 10:32 PM
96 SL Horn fuse blows ringagain S-Series Tech 5 05-02-2006 01:05 PM
95 SL2 blows cruise control fuse gkainz S-Series General 6 06-13-2005 08:22 AM
