Old 06-22-2009, 11:10 PM   #1
roktsyntst
roktsyntst is on a distinguished road
Dazed A/C blower on-bump-off-slow-fast-off- ..a/c blows cold
The heading about describes what I've got. It is hot in Texas- especially in my '98 sw2! Usually it will come on and blow cold and on high initially, but as I go it will slow, or stop...with or without bumps.I first noticed it with bumps and quick stops- it would come on. Seems to be getting less and less cooperative. I've been searching threads forever and can't find one that addresses this. Please help!!
roktsyntst is offline   Reply With Quote
Old 06-22-2009, 11:41 PM   #2
Default Re: A/C blower on-bump-off-slow-fast-off- ..a/c blows cold
Do you have a thermometer to monitor the center vent temperatures? They're inexpensive at most auto stores and fit well to give you an idea of how cool it can be. Average temps of 45F or lower is fine with the fan on med/hi speed. Another issue not described is whether or not you're having fan speed problems and if its related to a worn out fan if you use the a/c often throughout the summer. If you suspect a fan problem you'll have to check the wiring to the fan and if you can detect any burned wires suggesting poor/loose connections, especially the ground wire. Hopefully this is a fan issue and not an a/c problem.
Old 06-26-2009, 01:54 PM   #3
roktsyntst
Sorry to get back so late- the air is cold- the blower only works intermittently
or not at all. I guess I may need to replace it- or at least check it first. Where is it located in a SW2? How is it checked? Are there any other reasons for the on/off (mostly) off symptoms that I am experiencing?
Old 06-26-2009, 02:19 PM   #4
Oh, ok, its a blower issue. That's good and way better than a/c problems. Most blowers are under the passenger side glove box area. You can't miss it. A big round housing to enclose the squirrel cage fan, motor and wiring. Look carefully and locate the wiring connector to follow the wiring and see if there are any connections with discolored insulation suggesting loose connections otherwise your fan may be worn out. Check the ground connection too for looseness/discoloration of insulation.
Old 06-26-2009, 11:03 PM   #5
roktsyntst
Thank you- will try to get to it soon. It's 100+ degrees so I'll have to start early. I'll repost asap.Again- thanks!
Old 06-27-2009, 10:22 AM   #6
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
I just went through a similar issue.
http://www.saturnfans.com/forums/sho...d.php?t=140290
velleguy73 is offline   Reply With Quote
Good cold start, trouble starting when not cold, fast idle 2001 SL2 composerchris Community Center 2 12-05-2008 03:02 AM
AC Only Blows cold when driving. cptcrnch S-Series Tech 3 09-14-2008 03:05 PM
AC Blows too slow for Texas heat texwashere Vue Tech 7 07-11-2008 11:04 PM
driving slow cars fast is better than driving fast cars slow geartooth94 Classifieds 5 06-02-2006 08:44 PM
Bump,bump,bump, another alternator bites the dust Bill Murray S-Series Tech 2 10-05-2005 11:11 AM
