Old 09-14-2008, 10:27 AM   #1
cptcrnch
cptcrnch is on a distinguished road
1999 SC1
Default AC Only Blows cold when driving.
1999 SC1 Auto 130k. - Recently bought used.
My ac is only cold when driving above 30mph.
If I stop is goes warm ....FAST!!
Had my mechanic check it, says the system may have a plug in it somewhere. Coolant is NOT low.
Any other ideas b4 I have him start tearing the unit apart?
Thx!
cptcrnch is offline   Reply With Quote
Old 09-14-2008, 10:37 AM   #2
Asterixx
Asterixx will become famous soon enoughAsterixx will become famous soon enough
Asterixx's Avatar
1996 SL1
Default Re: AC Only Blows cold when driving.
Your two posts are related. The A/C is not working when stopped because the cooling fan is not forcing air through the condenser. When moving you're ramming air through. You need to fix the cooling fan.
1996 SL1 5m loaded except sunroof *SOLD*
1997 SL2 5m Loaded including sunroof, fog lights, and console bin.
Et nunc, reges, intelligite, er udimini, qui judacati terram
Asterixx is offline   Reply With Quote
Old 09-14-2008, 11:14 AM   #3
^ ^ What he said! ^ ^ ^
Old 09-14-2008, 03:05 PM   #4
lovinparkville
lovinparkville is on a distinguished road
2001 SW2
The 2 things to check are the fan relay and the fan itself. The relay turns on at high heat (@220 degrees) or on AC on IF the system has R134 at a proper level (which you indicate the system is fine while moving), I'd look at the fan relay for sure as it's rarely used under normal driving.
lovinparkville is offline   Reply With Quote
Park Light Fuse blows and blows. heavyd10000 S-Series Tech 6 09-14-2009 03:05 PM
A/C blower on-bump-off-slow-fast-off- ..a/c blows cold roktsyntst S-Series General 5 06-27-2009 10:22 AM
A/C blows hot after driving for an hour cullyhog Vue Tech 4 06-22-2009 06:12 PM
Reverse works when cold - gone after driving 3 miles. kim_lombard S-Series Tech 10 03-07-2008 07:15 PM
Cold Driving Noise - what is it DonP S-Series Tech 3 10-23-2006 09:08 PM
