Old 03-19-2007, 02:58 PM   #1
budward
budward is on a distinguished road
Default 96 SL2 - cylinder 4 misfire
My 96 keeps flashing the ses light and at Autozone it reads cyl 4 misfire. It idles rough but the misfire goes away with hard acceleration or if the rpm's stay up like when I hold in 3rd gear instead of Drive.. Gas mileage is way down also.
I have changed plugs, wires and coil pack.Could someone tell me other things I should check and in what order to check them. Too strapped to go to a garage.
Thanks...Bud
budward is offline   Reply With Quote
Old 03-19-2007, 04:23 PM   #2
wolfman
wolfman's Avatar
Default Re: 96 SL2 - cylinder 4 misfire
Poor compression and / a clogged fuel injector in that cylinder can also generate that code. Please also tell me you are NOT using platinum spark plugs..
Old 03-19-2007, 04:31 PM   #3
budward
thanks wolfman,
NO platinum plugs for me!
Wouldn't the two problems you described make poor performance all the time instead of low rpm?
Old 03-20-2007, 02:42 AM   #4
hardisk_c
hardisk_c is on a distinguished road
hardisk_c's Avatar
I suspect the miss is probably still there at the higher RPMS, but the torque gap is smaller so it seems to be running better. Wolfman's advice sounds on. . . next step would be to check the wiring to the injectors and perhaps swap the #4 injector with another and see if the miss follows. If it does, you have an injector issue, if not, see if you don't know anyone who could do a compression test for you in exchange for a 6-pack
hardisk_c is offline   Reply With Quote
Old 03-20-2007, 08:23 AM   #5
v3rs3
v3rs3 is on a distinguished road
It's not typical and normally happens during a cylinder 1 misfire, but you can try to spray some brake cleaner on the back of your head towards the intake gasket. These sometimes warp and can be causing a misfire. If it starts to run differently when you spray, you have a bad intake gasket.
v3rs3 is offline   Reply With Quote
Old 03-20-2007, 12:04 PM   #6
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
I would get a compression test. It sounds like the way mine was acting when I had a bent valve and was also setting a misfire code.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
blackeagle1 is offline   Reply With Quote
Old 03-22-2007, 01:29 AM   #7
budward
thanks for the input.
I will try the brake cleaner and change injectors around when I get a chance.Compression test if all else fails.
Old 03-22-2007, 03:46 AM   #8
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Compression test first.... I would almost bet you will find your problem there first....
Old 03-22-2007, 09:41 AM   #9
wolfman
wolfman's Avatar
His car is a 96' with the ALUMINUM INTAKE MANIFOLD. These are NOT prone to the vacuum and coolent leaks that the POS PLASTIC ONES used in the LATE 99' - 02' model years have.
That is EXACTLY how I would proceed. (Nice job)
Old 03-22-2007, 11:00 PM   #10
budward
Thanks to all that responded!
I have 3 jobs so will let everyone know how it turns out when I get the time to start checking stuff
97 Saturn SL2 - How to fix a Cylinder 2 Misfire? RussiaWolf S-Series Tech 4 10-10-2009 12:30 PM
97 SL2 Cylinder 4 misfire yoyodyne S-Series Tech 3 08-15-2007 10:05 PM
Misfire on cylinder 5 gtzman90 Vue Tech 0 02-17-2007 10:32 PM
96 sl2 P0302 Cylinder 2 misfire??? bskicrash1 S-Series General 15 12-26-2005 12:22 PM
Misfire cylinder#3 solo1279 S-Series Tech 6 11-08-2005 08:50 PM
