Old 01-14-2007, 11:53 PM   #1
dylanzachgabby
dylanzachgabby is on a distinguished road
Default 96 SL1 SOHC need help w/replacing head gasket
I need step by step instructions on changing my head gasket in 96 SL1.
Thanks
Dave
dylanzachgabby is offline   Reply With Quote
Old 01-15-2007, 12:39 AM   #2
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
Default Re: 96 SL1 SOHC need help w/replacing head gasket
First of all, are you sure it's the head gasket? What are the symptoms? The SOHC engines of that vintage are more prone to cracked heads.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
blackeagle1 is offline   Reply With Quote
Old 01-15-2007, 10:58 AM   #3
dylanzachgabby
My antifreeze reservoir is light brown creamy looking, I heard if the oil is mixing with antifreeze most likely it is a head gasket problem. If it is a cracked head how can I tell, I still would have to take it all apart to check right?
DM
Old 01-15-2007, 12:45 PM   #4
blackeagle1
2000 SL2
The brown mixture in the reservoir is definitely a sign of a cracked head. You have the remove the head and replace it. After that, you will have to do a thorough cleaning of the coolant system to get rid of the oil. Rebuilt heads can be found on eBay for around $300. Do a search on "cracked head" as there are lots and lots of posts on the subject.
Current Fleet:
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
Old 01-15-2007, 01:34 PM   #5
BarnOwl
BarnOwl's Avatar
The people to deal with on Ebay are Clearwater Cylinder Heads. Several people on here have gotten heads from them and been quite satisfied. Oh and yes, I'm telling you it's a cracked head too. The SOHC has more of a tendency to do that than other engines and the head gasket is practically bullet proof.
Old 01-15-2007, 05:55 PM   #6
eljefino
eljefino's Avatar
1995 SW1
you also need the following new parts when doing a sohc head gasket of that era:
intake and exhaust gaskets.
head bolts.
head.
Not being a smarmy pants but the people above are correct, the head has gone out.
If you look at the sticky interchange guide, you'll find years that'll work with yours.
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 03:40 PM
SOHC Alternator bracket oil puddle - head or head gasket? comanche S-Series Tech 10 09-28-2009 05:42 PM
SL1 SOHC - Post-Head Gasket Replacement Startup Issues atrain0007 S-Series Tech 8 04-03-2008 05:27 PM
95 s sohc head and head gasket questions bman S-Series Tech 16 01-07-2008 07:52 PM
Replacing the head gasket on 98 SL 98SLinNJ S-Series General 6 01-19-2005 11:42 AM
