Old 12-30-2006, 11:08 AM   #1
johnt671
johnt671 is on a distinguished road
Question Sl1 Head Gasket Replacement Cost?
My 48,000 Mile used motor in my 92 Sl1 has a slight leak in it. It's not leaking in the oil just leaving a small trail of coolent near the coils. Anyone got any ball park ideas of the cost to replace the head gasket? Thanks.
johnt671 is offline   Reply With Quote
Old 12-30-2006, 11:19 AM   #2
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Default Re: Sl1 Head Gasket Replacement Cost?
About $100 in parts if you do it yourself. Have you checked the coolant overflow bottle to make sure the head isn't cracked?
SaturnTech is offline   Reply With Quote
Old 12-30-2006, 02:59 PM   #3
johnt671
Checked the tank and it shows no sign of oil, and there are no bubbles or gunk on the oil filler cap or the dipstick, so I think it's just an external leak.
Old 12-30-2006, 03:52 PM   #4
Luke
Luke's Avatar
And check the top right radiator hose, which connects onto the radiator, at that location. You may simply have a connection where the clamp needs to be tightened. (((>speaking from personal experience, you understand <)))
Luke is offline   Reply With Quote
Old 12-30-2006, 05:42 PM   #5
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
i second the rad hose, dont jump to conclusions with head gaskets when they might not be needed... if you have a pkg of flour, spare time, and ready to get a little dirty, go to a car wash, was the engine (LIGHTLY) then put some flour everywhere, and watch for where the coolant comes from...
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
JS593 is offline   Reply With Quote
Old 12-30-2006, 06:51 PM   #6
johnt671
I'll go out in the morning and check it, but I'm 95 per cent sure it is coming out the the corner of the head. A while back I replaced the ECTS and not wanting to over tighten it I screwed it in until I felt pressure on it and then over the couse of a few days proceded to further tighen it until it wasn't leaking. The coolent puddled in the same spot but I was also able to see it around the ECTS. It looks dry in that area now but I'll also take a closer look there.
Old 12-31-2006, 01:34 PM   #7
johnt671
Mad Re: Sl1 Head Gasket Replacement Cost?
It's the head gasket. I dumped in some stop leak in and it seems to be holding the leak.
I really like this car and thought I got a good buy on it since it only had 82,000 miles on it when I got it,but I've dumped big bucks into it in a little more than a year. About 5 months after I bought it the motor siezed up and I had it replaced with one with 48,000 miles on it, but this motor seems to use more oil than the original motor, even though I did 2 MMO soaks and then started using 10w-30 weight oil. Now the head gasket is leaking and I'm not skilled enough to repair it.
At this point I may drive it until it blows up or take it back where I bought it and see if I can trade it in and stick it back on them. (I'm not to likely to do this because it's not thier fault and I believe they where honest about the car, But it seems like a good idea 'cause I'm not in the best of moods.)
Old 12-31-2006, 04:00 PM   #8
SaturnTech
SaturnTech's Avatar
Don't worry, with that stop leak floating around your cooling system...it won't be long before it clogs the radiator and/or heater core and your car is toast. You can't put a band-aid on a broken arm.
Old 12-31-2006, 07:51 PM   #9
JS593
JS593's Avatar
1992 SL1
haha.. that was good saturntech.... sorry to say it man, but hes right... the second a flow starts to get locked up, your entire car is going to blow up, that stuff you put in your rad, is meant for the rad... not for a head leak, get hte parts replaced, coolant flushed, or your going to look at a bigger bill then anticipated.
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
head gasket replacement wishihadacamaro S-Series General 10 07-23-2009 02:49 PM
cylinder head gasket replacement peter strawn L-Series Tech 15 02-27-2009 11:45 PM
Cylinder Head Gasket Replacement... twhitney S-Series General 10 01-11-2009 09:20 PM
SL1 SOHC - Post-Head Gasket Replacement Startup Issues atrain0007 S-Series Tech 8 04-03-2008 05:27 PM
no compression head gasket replacement jc91sc2 S-Series Tech 1 10-08-2003 08:27 PM
