Old 05-01-2006, 02:47 PM   #1
ringagain
ringagain is on a distinguished road
Attention 96 SL Horn fuse blows
Hello there,
I am a newbie to this forum but know enough to fix minor problems in my car. After this year's snowy Canadian winter, my horn stopped working. I checked under the hood and the fuse was blown. I replaced the fuse and it blew again. I tried a 15 amp fuse and that also blew. I tried to check the horn to see if it was melted or a nicked wire but every thing seems ok. My car has no electrical problems and there have been no alterations to the electrical system.
I was going through the forums and noticed a post by some one to use a Bosch relay and bypass the oem horn. Is there anything that I may be missing in my troubleshooting or if is there a way I can modify the 3 wire configuration and use a relay to install a regular 2 connector horn. I have checked with my local Saturn dealer for this OEM horn. It is a special order for $80 + tax.
Any help or suggestion will be much appreciated.
ringagain is offline   Reply With Quote
Old 05-01-2006, 03:08 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: 96 SL Horn fuse blows
Try unplugging the horn and reinsert a new fuse. Even go a far as hitting the horn buttons. If it still blows then there is a problem with the wiring, if it doesnt, its a problem with the horn itself.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 05-01-2006, 04:26 PM   #3
kanling
kanling is on a distinguished road
1991 VUE Red Line
Low has an excellent idea there.
kanling is offline   Reply With Quote
Old 05-01-2006, 05:09 PM   #4
You might try a boneyard for a replacement horn.
Old 05-02-2006, 12:26 PM   #5
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
Please make sure you put the correct fuse in when you do get it working. With the wrong fuse, you potentially turn the WIRING into the fuse. That leads to electrical fires.
You can tell Linux is made by geeks.
RangerRover is offline   Reply With Quote
Old 05-02-2006, 01:05 PM   #6
Gbody403
Gbody403 is on a distinguished road
I went to the junk yard for 3 horns before I found one that worked. It was also a (2) terminal horn. My 96' SC2 had a 3 terminal plug so I tested each one with a multimeter to find out which ones completed a circuit when the horn button was pressed. It works OK now. Last week I was shopping at Harbor Frieght tools and found the exact same horn NEW for about $10!!. If I remember right the horn is made in France. It is a (2) terminal horn (for 95 and older Saturns??) and is identical to OEM. Hope that helps.
Gbody403 is offline   Reply With Quote
horn trouble-no power to horn/not fuse 2xsl2 S-Series Tech 6 03-06-2010 11:32 PM
Park Light Fuse blows and blows. heavyd10000 S-Series Tech 6 09-14-2009 03:05 PM
Fuse Blows motttocs S-Series Tech 9 10-22-2007 05:01 PM
Fuse blows everytime I replace it? solidusjoe S-Series Tech 6 08-30-2007 08:45 AM
No wiper/washer. Fuse blows! peppermrj S-Series Tech 3 05-06-2007 10:32 PM
