Old 10-23-2004, 09:48 PM   #1
plum_sc2
plum_sc2 is on a distinguished road
1993 SC2
Default cooling system refill problem.....
........drained the rad and block, about 6 qts came out.....did a flush with the prestone stull but didn't seem to take the 7 qt capacity....... and the high coolant temp ligh now flashes...........did a second flush and same results...................
my question is.........is there a trick to making sure the system is full?
1993 SC2 - 168,000 miles
2003 Vue - 104,000 miles
plum_sc2 is offline
Old 10-23-2004, 11:04 PM   #2
Tiger
Tiger's Avatar
Default
Did you get the air out of the system? Wolfman has some nice instructions here for flushing and filling. Is this what you did?
http://www.saturnfans.com/forums/sho...threadid=38845
Tiger is offline
Old 10-23-2004, 11:38 PM   #3
plum_sc2
1993 SC2
Default
third time is a charm.......all 7 qts went in
only problem now is the hi coolant temp light still blinks
plum_sc2 is offline
Old 10-24-2004, 08:39 PM   #4
LATEMODELRACING
LATEMODELRACING is on a distinguished road
Default
is the car overheating??
LATEMODELRACING is offline
Old 10-24-2004, 08:48 PM   #5
plum_sc2
1993 SC2
Default
no................. and i started it this morning and no light
soooooooo we'll drive it to work monday and see what happens
plum_sc2 is offline
Old 10-24-2004, 09:27 PM   #6
lukecp
lukecp is on a distinguished road
lukecp's Avatar
1997
Default
My light has been on since i bought my car. When i bought it the car had a bad radiator and was low on coolant. The dealer replaced the radiator for free, light still blinked even though coolant was full. The light is still on, and the car is full of coolant and dosen't over heat. I'm contemplating pulling the clear cover over the guages and putting a piece of electrical tape over it so i don't have to look at it anymore.
2000 Subaru Forester L, 5MT
FORMER: 1997 SL, 5MT
lukecp is offline
Old 10-24-2004, 11:22 PM   #7
amazinghl
Default
Check your tranny fluid.
00 Insight 72mpg
amazinghl is offline
Old 10-25-2004, 11:06 AM   #8
Default
Luke, did you (or the dealer when they replaced the rad) pull the PCM fuses for a few seconds? Might be worth a try. Wolfman could obviously answer this more intelligently, but I'd bet that once that hi-temp light is "set", it doesn't reset simply by fixing the coolant sitch.
madpogue is offline
Old 10-25-2004, 12:45 PM   #9
lukecp
lukecp's Avatar
1997
Default
Humm.....i don't know. The repair was done at an independent shop (got the car from a run-of-the-mill used dealer), and my parents picked it up for me so i didn't get a chance to talk to the mechanic.
So....just remove the fusebox cover, and pull the PCM fuse for maybe 30 seconds? Should i do it with the ignition on? I've also heard of removing the negative battery cable to reset the computer. Would be nice to get rid of that pesky light.
lukecp is offline
Old 10-26-2004, 06:38 AM   #10
eljefino
eljefino's Avatar
1995 SW1
Default
Should be an electrical connector on the surge tank (thing with "radiator" cap) that runs the "low coolant" light. Unplugging this should turn off the light.
The floats for low coolant level get sticky and either need extra coolant above the "full" line, cleaning, or disabling... depending on your ambition and tolerance for having less warning info.
eljefino is offline
Old 10-28-2004, 11:17 PM   #11
plum_sc2
1993 SC2
Default
hmmmmmmmmmm......... i'm still getting the light and the resivoir has needed filling twice now.........
plum_sc2 is offline
Old 10-28-2004, 11:53 PM   #12
sierrap615
sierrap615's Avatar
Default
if it blinks you may need a new ECT
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-29-2004, 03:33 AM   #13
wolfman
wolfman's Avatar
Default
IF the light FLASHES, (at a regular on/off/on/off pace) it is an indicator that the PCM is getting NO DATA from either the ECTS, TTS (automatics only) or a combination of very different readings from both. Odds are good this is a ECTS or connector issue or a TSS (Transaxle temperature sensor) issue. IF it is NOT a "regular" pulsing flash, the coolant level sensor in the resevoir tank may just be gunked up. DO NOT "disable it" it is EASY and FREE usually to fix. Just drain enough coolant out to make the tank run dry, remove the tank and rince it out with a strong soap and water or Castrol Super Clean and water solution followed by several clean water rinces. That is all that is usually needed to free up the stuck float in the tank that causes this problem basicaly permanently.
wolfman is offline
Old 10-31-2004, 08:50 PM   #14
plum_sc2
1993 SC2
Default
when it flashes, the coolant is low...........but i don't leave a puddle
maybe it's just cause its halloween??!!
plum_sc2 is offline
Old 10-31-2004, 09:24 PM   #15
Chris101
Chris101 is on a distinguished road
Chris101's Avatar
Default
Is your head gasket cracked? Does the exaust smell kinda sweet?
Chris101 is offline
Old 10-31-2004, 09:29 PM   #16
plum_sc2
1993 SC2
Default
not that i am aware of, wouldn't i be getting excessive smoke out the tailpipe? or a fluid drip from the tailpipe?
i gotta change the oil this week, i'll run a blacklight over the old oil for traces of coolant..............
plum_sc2 is offline
Old 11-01-2004, 12:54 AM   #17
sierrap615
sierrap615's Avatar
Default
sorry but no. if its steady, then the coolent is low(trust me, i had two coolent leaks in three weeks)
Old 11-01-2004, 10:08 AM   #18
MBman
MBman is on a distinguished road
Default
Sounds like a head gasket to me. Does your oil cap have "froth" on the underside?
Also make sure your radiator cap is making good seal.
I had a leak in my radiator one time (not on my saturn) that leaked and blew directly onto the exhaust, never had signs of a puddle.
Good luck.
MBman is offline
Old 11-01-2004, 10:26 AM   #19
plum_sc2
1993 SC2
Default
no froth on the oil cap, NO cap on the radiator........... you must be talking about the resevoir cap, seal look good and i cleaned that tank out when i flushed the system.............
gonna take a GOOD look around when i do the oil change............
plum_sc2 is offline
Old 11-01-2004, 10:07 PM   #20
plum_sc2
1993 SC2
Default
resevoir has needed filling AGAIN!!!!!!!!!!!
plum_sc2 is offline
Cooling System Problem? kyasarin S-Series Tech 7 07-26-2009 09:14 AM
Cooling System jdw34 Vue Tech 2 07-23-2008 06:14 PM
Weird cooling system problem sc2095 S-Series Tech 11 07-29-2004 07:58 PM
Cooling System over pressure problem flyingw80 S-Series Tech 22 10-23-2003 11:36 AM
Cooling system problem looneyluden Miscellaneous Tech 6 10-25-2000 07:41 PM
