Old 07-28-2004, 05:55 PM   #1
sc2095
sc2095 is on a distinguished road
sc2095's Avatar
Default Weird cooling system problem
I helped my friend replace his waterpump on his 93 SC2 yesterday, cause it finally died. We filled the system back up with water and coolant, and then let it run to check for leaks. It was working perfectly. We went for a drive, and noticed that the car started to heat up, and wouldn't cool back down. We took it home, and everything seemed ok, but when the car was cold, he took off the coolant resevior cap, and coolant came running out of it. He filled it back up to the lower level, and then went for a drive again. The same thing happened, only it took longer for the engine to heat up. Any idea why this is happening? The thermostat is opening up because both radiator hoses heat up and he has lots of heat in the car.
sc2095 is offline
Old 07-29-2004, 12:43 AM   #2
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
A few questions. How hot is the car getting when you guys are driving it around? The system is pressurized so it will spew coolant if you take the cap off too fast.
Did you check the all the hoses for a collapsed hose? Does the fan turn on when your temp needle reaches the 3/4 mark? When's the last time you changed the ECTS?
SLeepr is offline
Old 07-29-2004, 12:44 AM   #3
94sc295sl2
94sc295sl2 is on a distinguished road
94sc295sl2's Avatar
Location: spring hill tennessee (the motherland) sterling heights michigan native
1994 SL1
Default
start the car and let it run with the radiator cap off until it gets hot. sound slike you have a ari bubble in the system
remember that cars are built by robots built by human hands and are prone to failure.
94sc295sl2 is offline
Old 07-29-2004, 02:27 AM   #4
amazinghl
Default
And DO NOT put the cap back on until the engine is COLD!
Did you also change out the thermostat?
00 Insight 72mpg
amazinghl is offline
Old 07-29-2004, 04:05 AM   #5
wolfman
wolfman's Avatar
Default
Saturn cooling systems are self purging...it's NOT an "air bubble" Either the water pump taint pumping, (it's new so unless the belt is slipping horribly..unlikely) the radiator is internally clogged or externally blocked airflow wise (put a piece of carboard or? to protect it while you were working around it?) or the thermostat IS sticking shut. My money is on the thermostat. NOTE: The heater WILL get hot water (produce heat) LONG before the thermostat opens...it's designed that way. It IS possible for the upper and lower radiator hoses to be warm and the thermostat to still be stuck fully or partially closed.
wolfman is offline
Old 07-29-2004, 06:49 AM   #6
sc2095
sc2095's Avatar
Default
I think it's on the original thermostat, and the temp will increase all the way to the red mark, until the fan comes on, then it just stabilizes really high and doesn't come back down until you shut the car off. The temp goes up quicker with faster car speed.
sc2095 is offline
Old 07-29-2004, 10:50 AM   #7
amazinghl
Default
Change it.
00 Insight 72mpg
Old 07-29-2004, 11:19 AM   #8
wrg813
wrg813 is on a distinguished road
Default
Fan coming on with temp gauge in red, sounds like the fix all ECT sensor is not reading correctly. Just a thought.
wrg813 is offline
Old 07-29-2004, 03:42 PM   #9
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
Default
IIRC you can get an OEM stat & ECTS for about 20 bucks total.
Bill Murray is offline
Old 07-29-2004, 04:33 PM   #10
TedL
TedL is on a distinguished road
Default
Better make that $30; $18 for the t-stat, $12 for the ECTS>
TedL is offline
Old 07-29-2004, 05:59 PM   #11
Qlara
Qlara's Avatar
Default
I'd also check the correctness of coolant-water mix-ratio.....
Maybe too much water in the coolant? Typical mix should be 50/50 (water/green) and some extreme weather may require 30/70 or 20/80.....depends.
Qlara is offline
Old 07-29-2004, 07:58 PM   #12
lpkortuem
lpkortuem is on a distinguished road
Default
Wolfman is right! Saturns purge air very quickly through the Small lines at the top of the reservoir. You might consider that your friend got the thing hot at the time he discovered the leaking pump and it now has head or headgasket troubles. I'm assuming that before he got into the water pump trouble thing that it was acting normally.
lpkortuem is offline
Weird Cooling Fan problem Dime333 S-Series Tech 6 08-05-2009 10:02 AM
Cooling System Problem? kyasarin S-Series Tech 7 07-26-2009 09:14 AM
cooling system refill problem..... plum_sc2 S-Series General 32 01-08-2005 01:09 PM
Cooling System over pressure problem flyingw80 S-Series Tech 22 10-23-2003 11:36 AM
Cooling system problem looneyluden Miscellaneous Tech 6 10-25-2000 07:41 PM
