Old 10-03-2016, 06:30 PM   #1
jcm22
jcm22 has a spectacular aura aboutjcm22 has a spectacular aura aboutjcm22 has a spectacular aura about
2002 SL
Default 02 Saturn SL misfire at idle only
First I would like to thank everyone that has helped me in the past with my tech issues.
I am currently having an issue with the engine misfiring at idle.
I purchased this vehicle brand new back in 2002.
It currently has 51,000 original miles on it. (I know I don't drive the thing )
Recent history - back in April 2016 I finally replaced the original spark plug wires.
I changed the plug wires and replaced the spark plugs as well (autolite)
Car ran beautifully til' one day I noticed it was misfiring when I came to a complete stop. It was misfiring pretty violently so I went back to the store and brought back the wires. I install the new wires and it kept on misfiring but not as violently. I then replaced the Autolite spark plugs and installed AC Delco spark plugs. Misfiring still happens but not as violently.
A friend then mentioned it could be bad gas /water in the gas....so I dumped a bottle of fuel injection cleaner and HEET additive (to remove possible water) and filled it with fresh gas. Ran around and placed quite an enormous amount of miles on my car this weekend. The car runs like a bear while driving and I feel no hesitation, bucking or kicking when on the highway or city driving. Once I come to a stop then it acts up and starts misfiring.
Is there something else that would be causing my engine to misfire under idle?
I know it is time to replace the fuel filter...maybe I should start there?
What am I missing or overlooking? I want to hang onto this car for at least another 10 years
Thank you for any help or wisdom you can share with me.
jcm22 is offline   Reply With Quote
Old 10-03-2016, 08:00 PM   #2
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Default Re: 02 Saturn SL misfire at idle only
Take a can of carb or brake cleaner and spray it around the number 1 intake port where it meets the cylinder head. If the engine speeds up, the intake gasket is bad.
Old 10-03-2016, 09:32 PM   #3
jcm22
2002 SL
Thank you for the suggestion. I will give that a try tomorrow.
Old 10-04-2016, 08:05 PM   #4
jcm22
2002 SL
bluesl2 you were right on. Brake cleaner aimed at the # 1 intake port didn't rev my engine up however it almost choked my car into stalling. Thanks for your assistance.
Old 10-05-2016, 09:47 AM   #5
BV22
2002 SC1
There is a good write up on gasket replacement in the "How To" section here. It is a 3 - 4 hour job and not too difficult. Almost all of us 3rd gen SOHC owners have done the gasket replacement at some point, myself included.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 10-05-2016, 12:52 PM   #6
marko16
marko16 is a jewel in the roughmarko16 is a jewel in the roughmarko16 is a jewel in the rough
Poor idle performance can be a dirty egr. If you clean it up, it may ladle fine.
marko16 is offline   Reply With Quote
Old 10-05-2016, 03:03 PM   #7
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Try cleaning your throttle body...
You will need some 6 point metric sockets, FEL-PRO Part # 61177 gasket, T20, and T25 screwdrivers, and some carb cleaner...
Richpin video...
https://youtu.be/Pc5qCuQLmFE
Also plain copper NGK plugs work best, I am running the V-Powers, in one heat range colder than normal...
For the SOHC, that would be BKR5E-11...
http://www.ngksparkplugs.ca/results-...L&aaia=1040921
Mobil 1 ESP 0W-30, NAPA Gold 51516...
NGK BKR6E-11 spark plugs
Old 10-05-2016, 05:31 PM   #8
jcm22
2002 SL
After spraying brake cleaner near the #1 intake port and having the car "choke" on me, (drop in rpm and nearly stall out) I do not believe this situation involves a dirty throttle or EGR. Stay tuned....
Old 10-09-2016, 10:06 PM   #9
jcm22
2002 SL
Intake gasket has been replaced and no more misfiring. Thank you to those that chimed in.
Misfire at Idle Leemanfor L-Series Tech 11 09-23-2015 04:45 PM
misfire at idle RonM L-Series Tech 2 09-20-2010 02:07 AM
Misfire, Rough Idle getz_999 S-Series Tech 2 07-15-2010 02:59 PM
Idle Misfire. OnDaGround S-Series Tech 6 10-20-2009 07:29 AM
01 SC-1 Stumbling Idle/Misfire BLINE S-Series Tech 6 03-24-2005 12:34 PM
