#1 |
![]() Join Date: Jul 2009
2002 SC1
Hello im new to this site. and im sure this has been covered before already but as I was looking i seen like 1400 threads. so ill just start over....
I have a 2002 Saturn SC1 that has a Misfire that comes and it goes. I dont understand it. When I have the Code Read it comes back Cyl 2 misfire. But its really werid. It happens for a while then it stops and I can drive the car for about 500 miles then it will just start up again. So far I have replaced the Intake Manifold gasktet (used to be a cyl 1 misfire) that fixed that problem. Then the Catt out so it has a bran new catt. it has new spark plugs and wires. the coils dont look bad at all either. im totally lost can anyone help. ![]() |
#2 |
Welcome to the forums!
Here is a cheap test that should help solve your spark issue: You can try switching the coils between each other and then if you have spark issues with the new plug it is connected to you will know if it is the coil that is bad. On the other hand, if you are still managing to get a misfire on the 2nd cylinder with the coils switched you can look at getting a new ignition control module. I would test it that way first that way you save some $$$ by not having to replace parts that still work. ![]()
Former DD: 1994 SC2 5spd. 190K, being sold to a friend 2005 Saturn ION 2 5spd. 73K 1995 Aquamarine SL2 1.9L DOHC 5spd. ~125K Miles |
#3 |
2002 SC1
How do you get the coils off to switch them around?
#4 |
There are a couple 8mm bolts in each coil. Unbolt them and they'll unplug from the ignition module.
There is nothing more frightening than ignorance in action. |
#5 |
2002 SC1
Thanks ill have to try that. I replaced the wires and plugs again, the car seems to be running find for now. But the problem comes and goes so ill see what happends
#6 |
![]() Join Date: Apr 2009
What kind of plugs are you running. Use the NGK non platinums. Also while you have module and coil packs off your Auto Zone should have cables to test the module just be careful pluggin in easy to bend a pin or 2
Bookmarks |
Tags |
misfire |
05 ion p0300 multiple/random misfire | pimp05ion | Ion General | 4 | 05-18-2009 02:24 AM |
05 ion p0300 multiple/random misfire | pimp05ion | Ion General | 0 | 05-15-2009 11:20 PM |
2000 LS2 Code 300 Random Misfire | rjmotor | L-Series Tech | 10 | 01-02-2009 03:42 PM |
96 sl1 random misfire | milk001 | S-Series Tech | 12 | 03-10-2005 09:22 PM |
Random misfire (P0300) under heavy load | 98greenSC2 | S-Series Tech | 11 | 03-03-2005 02:06 AM |
